Broken image
Broken image
I first thought I had a driver problem but I can get images from my cam useing tvtime. When I pull up the moniter window in ZM i get a broken image icon and I have no idea where to start. This is the first time I have tried something complex like this. I followed the FC6 Wiki but nothing. Where should I look first?
OS fedora6
Card Pv 153
OS fedora6
Card Pv 153
Here is an error I'm getting in my system log
Dec 21 21:41:38 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 21 21:43:07 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
Dec 21 21:43:07 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/21 21:43:07, pid = 3832]
Dec 21 21:43:07 vserver zmdc[3832]: INF ['zmc -d /dev/video0' started at 06/12/21 21:43:07]
Dec 21 21:43:07 vserver zmc_dvideo0[3832]: INF [Debug Level = 0, Debug Log = <none>]
Dec 21 21:43:07 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
This suggests that zm is not able to capture an image from the device and confirms your problem.mikesjays wrote: Dec 21 21:41:38 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Have you turned up the debug?
Are there no other errors in any of the other logs?
here are the results of dmesg | grep -4 bttv
SELinux: Disabled at runtime.
SELinux: Unregistering netfilter hooks
audit(1166734441.840:2): selinux=0 auid=4294967295
Linux video capture interface: v2.00
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:02:08.0[A] -> Link [LNKD] -> GSI 10 (level, low) -> IRQ 10
bttv0: Bt878 (rev 17) at 0000:02:08.0, irq: 10, latency: 64, mmio: 0xf69f8000
bttv0: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
bttv0: using: ProVideo PV150 [card=98,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (1).
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:02:09.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
bttv1: Bt878 (rev 17) at 0000:02:09.0, irq: 11, latency: 64, mmio: 0xf69fa000
bttv1: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
bttv1: using: ProVideo PV150 [card=98,autodetected]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: using tuner=-1
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
PCI: setting IRQ 9 as level-triggered
ACPI: PCI Interrupt 0000:02:0a.0[A] -> Link [LNKB] -> GSI 9 (level, low) -> IRQ 9
bttv2: Bt878 (rev 17) at 0000:02:0a.0, irq: 9, latency: 64, mmio: 0xf69fc000
bttv2: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
bttv2: using: ProVideo PV150 [card=98,autodetected]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: using tuner=-1
bttv2: i2c: checking for TDA9875 @ 0xb0... not found
bttv2: i2c: checking for TDA7432 @ 0x8a... not found
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .<6>i810_smbus 0000:00:01.0: i810/i815 i2c device found.
. ok
bttv: Bt8xx card found (3).
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
ACPI: PCI Interrupt 0000:02:0b.0[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
bttv3: Bt878 (rev 17) at 0000:02:0b.0, irq: 11, latency: 64, mmio: 0xf69fe000
bttv3: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv3: using: ProVideo PV150 [card=98,autodetected]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: using tuner=-1
bttv3: i2c: checking for TDA9875 @ 0xb0... not found
bttv3: i2c: checking for TDA7432 @ 0x8a... not found
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .. ok
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
ACPI: PCI Interrupt 0000:02:08.1[A] -> Link [LNKD] -> GSI 10 (level, low) -> IRQ 10
bt878_probe: card id=[0x1460aa00], Unknown card.
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
Bluetooth: HIDP (Human Interface Emulation) ver 1.1
eth0: no IPv6 routers present
bttv0: PLL can sleep, using XTAL (28636363).
. ok
Okay, that shows that the devices are initialized and we already know they work since you have them working with tvtime, but yields no errors as I requested.
Try using:
tail -f /tmp/zm*.log /var/log/messages
adjust the paths as required and start zm to see what transpires.
You might need to turn up the debug and check the debug logs.
Try using:
==> /tmp/zmaudit.log <==
12/23/2006 07:55:09.735378 zmaudit[2243].DBG [Found filesystem monitor '1']
12/23/2006 07:55:09.735936 zmaudit[2243].DBG [Got 0 events]
12/23/2006 08:10:09.745927 zmaudit[2243].DBG [Found database monitor '1']
12/23/2006 08:10:09.747893 zmaudit[2243].DBG [Got 0 events]
12/23/2006 08:10:09.749082 zmaudit[2243].DBG [Found filesystem monitor '1']
12/23/2006 08:10:09.749858 zmaudit[2243].DBG [Got 0 events]
12/23/2006 08:25:09.771931 zmaudit[2243].DBG [Found database monitor '1']
12/23/2006 08:25:09.773903 zmaudit[2243].DBG [Got 0 events]
12/23/2006 08:25:09.775062 zmaudit[2243].DBG [Found filesystem monitor '1']
12/23/2006 08:25:09.775838 zmaudit[2243].DBG [Got 0 events]
==> /tmp/zmdc.log <==
12/23/2006 08:37:14.154303 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:14, pid = 25575]
12/23/2006 08:37:14.227949 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:37:24.994152 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:24, pid = 25579]
12/23/2006 08:37:25.057644 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:37:35.849854 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:35, pid = 25600]
12/23/2006 08:37:35.916751 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:37:46.669718 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:46, pid = 25605]
12/23/2006 08:37:46.730660 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:37:57.518058 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:57, pid = 25609]
12/23/2006 08:37:57.587457 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
==> /tmp/zmfilter.log <==
12/23/2006 08:29:23.225555 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:30:23.228448 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:31:23.231278 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:32:23.506008 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:33:23.521126 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:34:23.527785 zmfilter[2237].DBG [Reloading filters]
12/23/2006 08:34:23.545681 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:35:23.550540 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:36:23.554269 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:37:23.560978 zmfilter[2237].DBG [Sleeping for 60 seconds]
==> /tmp/zmpkg.log <==
12/20/2006 22:26:11.540006 zmpkg[9884].INF [Command: start]
12/20/2006 23:23:54.255445 zmpkg[24881].INF [Command: stop]
12/21/2006 06:31:42.253730 zmpkg[2191].INF [Command: start]
12/21/2006 17:18:43.641774 zmpkg[31516].INF [Command: stop]
12/21/2006 17:25:41.011687 zmpkg[2159].INF [Command: start]
12/21/2006 17:55:07.963532 zmpkg[2178].INF [Command: start]
12/21/2006 20:46:32.587884 zmpkg[8938].INF [Command: stop]
12/21/2006 20:54:54.065436 zmpkg[2158].INF [Command: start]
==> /tmp/zmupdate.log <==
12/20/2006 22:26:23.909780 zmupdate[9935].INF [Checking for updates]
12/20/2006 22:26:24.627371 zmupdate[9935].INF [Got version: '1.22.3']
12/21/2006 22:55:13.319698 zmupdate[2258].INF [Checking for updates]
12/21/2006 22:55:15.507297 zmupdate[2258].INF [Got version: '1.22.3']
12/22/2006 22:55:15.728641 zmupdate[2258].INF [Checking for updates]
12/22/2006 22:55:16.099971 zmupdate[2258].INF [Got version: '1.22.3']
==> /tmp/zmwatch.log <==
12/23/2006 08:37:25.077770 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:24, pid = 25579]
12/23/2006 08:37:35.086887 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:37:35.088259 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:37:35.878994 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:35, pid = 25600]
12/23/2006 08:37:45.890195 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:37:45.891559 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:37:46.745207 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:46, pid = 25605]
12/23/2006 08:37:56.753818 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:37:56.755122 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:37:57.609085 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:57, pid = 25609]
==> /var/log/messages <==
Dec 23 08:37:46 vserver zmc_dvideo0[25605]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:37:46 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Dec 23 08:37:46 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:46, pid = 25605]
Dec 23 08:37:56 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:37:56 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:37:57 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:57, pid = 25609]
Dec 23 08:37:57 vserver zmdc[25609]: INF ['zmc -d /dev/video0' started at 06/12/23 08:37:57]
Dec 23 08:37:57 vserver zmc_dvideo0[25609]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:37:57 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Dec 23 08:37:57 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:57, pid = 25609]
12/23/2006 08:38:07.621647 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:07.622939 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:07 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:07 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:08.465332 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:08, pid = 25615]
12/23/2006 08:38:08.545150 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:08.515263 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:08, pid = 25615]
Dec 23 08:38:08 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:08, pid = 25615]
Dec 23 08:38:08 vserver zmdc[25615]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:08]
Dec 23 08:38:08 vserver zmc_dvideo0[25615]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:08 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:08, pid = 25615]
Dec 23 08:38:08 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:18.528817 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:18.530114 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:18 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:18 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:19.364992 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:19, pid = 25619]
12/23/2006 08:38:19.442373 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:19.415761 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:19, pid = 25619]
Dec 23 08:38:19 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:19, pid = 25619]
Dec 23 08:38:19 vserver zmdc[25619]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:19]
Dec 23 08:38:19 vserver zmc_dvideo0[25619]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:19 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:19, pid = 25619]
Dec 23 08:38:19 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:23.567097 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:38:29.438879 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:29.440171 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:29 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:29 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:30.296498 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:30, pid = 25623]
12/23/2006 08:38:30.364321 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:30.377960 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:30, pid = 25623]
Dec 23 08:38:30 vserver zmdc[25623]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:30]
Dec 23 08:38:30 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:30, pid = 25623]
Dec 23 08:38:30 vserver zmc_dvideo0[25623]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:30 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Dec 23 08:38:30 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:30, pid = 25623]
12/23/2006 08:38:40.384970 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:40.386284 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:40 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:40 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:41.216699 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:41, pid = 25627]
12/23/2006 08:38:41.280530 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:41.297907 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:41, pid = 25627]
Dec 23 08:38:41 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:41, pid = 25627]
Dec 23 08:38:41 vserver zmdc[25627]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:41]
Dec 23 08:38:41 vserver zmc_dvideo0[25627]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:41 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Dec 23 08:38:41 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:41, pid = 25627]
12/23/2006 08:38:51.309225 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:51.310576 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:51 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:51 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:52.220322 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:52, pid = 25631]
12/23/2006 08:38:52.373237 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:52.250589 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:52, pid = 25631]
Dec 23 08:38:52 vserver zmdc[25631]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:52]
Dec 23 08:38:52 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:52, pid = 25631]
Dec 23 08:38:52 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:52, pid = 25631]
Dec 23 08:38:52 vserver zmc_dvideo0[25631]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:52 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
What exactly did you do? -- I followed the readme and am still getting:mikesjays wrote:Ok that did the trick, thank you all for the help
04/01/07 01:06:02.434151 zmwatch[22999].INF ['zmc -d /dev/video' starting at 07/01/04 01:06:02, pid = 23173]
04/01/07 01:06:12.435894 zmwatch[22999].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
04/01/07 01:06:12.436309 zmwatch[22999].INF [Restarting capture daemon for Philips, shared memory not valid]
it appears your using an saa based card. If i were you that doesnt look related to this thread start a new topic detailing as much info as you can ie card type logs etc
James
James
James Wilson
