Odd Behavior With a Bttv 878 card
jayson.barker
Post by jayson.barker »
First of, Merry Christmas!
I have searched the forums for a couple of days now, hoping to find solutions to my problem. I have managed to get the card working alot better then before by specifying card type 77,.
I am unsure to the exact make of the card, but it came bundled with the Pico 2000 software for windows, which is no use to me as i am using Linux, but a quick google revealed it was infact a 878 card, and i should use type 77.
My issue is that the image displays with a distorted view, and i have scanlines over the image such as:
the Camera is a Swann Nightvision camera from Maplin and is PAL. For some reason i get ( ever so slight ) improvements with it set to AUTO for the device format.
Any suggestions would be appreciated.
Regards
Jay
jameswilson
Post by jameswilson »
how did you specify 77?
ebay special i assume, do you have a pic of the card
James Wilson
jayson.barker
Hey,
Yes it was an ebay special :oops: , My boss at work bought it for me.
The card looks identical to this:
http://www.zorg.org/homeauto/pico2000.php
And it has the words UCL UCC4 on the back of the PCB.
I specified the options in the modprobe.conf
jameswilson
lol, how did you specify the options as it should work.
its either a duff modprobe line or camera/card
have you proved the cam
James Wilson
jayson.barker
This is the line i added to the bottom of /etc/modprobe.conf:
options bttv card=77 tuner=-1
To be fair, i have not tested the camera, the card worked fine in Windows With another Swann cam, i will go test the other Cam now.
jayson.barker
is this normal output?
[root@server01 ~]# dmesg | grep bttv
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:02:04.0, irq: 16, latency: 32, mmio: 0xec000000
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00f360ff [init]
bt878: Unknown symbol bttv_read_gpio
bt878: Unknown symbol bttv_write_gpio
bt878: Unknown symbol bttv_gpio_enable
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... <6>Non-volatile memory driver v1.2
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
jameswilson
yeah that looks ok, id check the cam
James Wilson
KegRaider
Post by KegRaider »
Thanks Jameswilson for your pointers. As usual, your tips help me get my system running sweetly.
Adding options bttv card=77 tuner=-1 to /etc/modprobe.conf fixed my el'cheapo ebay bt878 card and make spring to life in the LiveCD of v1.21.0. Actually, it looked like it was in NTSC mode, and I have PAL cameras.
I wanted to try these cards as you can pick them up for about AU$30 delivered. (http://cgi.ebay.com.au/ws/eBayISAPI.dll ... :IT&ih=017)
Time to order 2 more cards and a few cameras (plan on 12 total), then i can remove these USB cameras I have on my WinXP machines using dcam and apache :P
Regards,
KegRaider.
