Problem with monitor view
herrmanna
Post by herrmanna »
I have installed zoneminder and I have config a monitor with a hauppauge bttv card
Source = video0
Cahnnel=1
when i click to Monitor name then open a windows with alternate text on imagebox i see not the preview from cam when i going to zones then i see the picture of cam.
have you an tip????
BR
Herrmann
jameswilson
Post by jameswilson »
What os are you using?
Anythinfg in the logs?
James Wilson
herrmanna
Ok Monitor works now I have change the options no mpeg
Post by herrmanna »
Hi
I use now cambozola and its works.
But I become no events i have setup a zone and when i going in forground of cam then i become no events.
It's psoible for setup the images for one event I need not every ms a image i need every 1 seconds 2 images.How can I condfigure that???
BR
herrmann
herrmanna
I have follow errors in the Browser
Post by herrmanna »
1. Warning: Division by zero in /usr/local/httpd/htdocs/zm_html_view_montage.php on line 54 -
when i clicking onmontage
2. Warning: Division by zero in /usr/local/httpd/htdocs/zm_html_view_cycle.php on line 69
Warning: Division by zero in /usr/local/httpd/htdocs/zm_html_view_cycle.php on line 70
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 101
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 102
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 103
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 104
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 105
When I clicking on Cycle
3.Fatal error: Call to undefined function: glob() in /usr/local/httpd/htdocs/zm_funcs.php on line 1764
when I clicking on Options System Tab
Can you help me????
zoneminder
Site Admin
Post by zoneminder »
How many monitors do you have defined, and what are they set to do?
Phil
herrmanna
point 1 to point 2 are works now but point 3
Post by herrmanna »
Hello
Montage and cycle works now you have right I have not correct the monitors.
But the point 3 I can not find a solution.
I need the seetings for pan and tilt and this is finding on tab system but I become the point 3 message.
Can you interpret this???
BR
herrmann
Cell
Post by Cell »
If I may add my two cents worth, having had the same problem. The Montage view being devoid of anything, and the Zone Minders logs not reporting any errors.
The error in the Apache log:
"Division by zero in /usr/local/httpd/htdocs/zm_html_view_montage.php on line 54"
Was resolved when I placed my monitors into a group as specified in the Readme.pdf page 20 second last paragraph before "8.2 Defining Zones"
Hope this helps
Cell
Neglected to mention:
ZoneMinder 1.22.3
OS = Slackware 11
Kernel 2.6.19.1
PHP 5.2.0
