(Incombatibility) Asus A7N266-VM Motherboard
StephenOz
Post by StephenOz »
Just some info for others. It seems the Asus A7N266-VM Motherboard has problems with Linux (nVidia nForce chipset).
Blueberry Live CD Boots & installs but has capture problems.
ZM Live CD 1.22.2.1 does complete boot.
FC 6 also does not complete boot.
So if your in the hunt for a machine best to avoid this motherboard.
cordel
Post by cordel »
What version of BIOS?
Have you updated the BIOS to the current version?
Have you tried to remove any extra peripherals (capture cards, modems, etc. that may not be initially supported by the kernel version on the install CD)?
StephenOz
Post by StephenOz »
I went to upgrade the bios but had the latest already (I must of done that when I 1st got it some time ago)
Yes & disabled everything in bios :( :( . Google = many people having problems with the board & linux :(
jameswilson
Post by jameswilson »
i resigned myself to intel only chipsets a while ago. To the point that i now only use intel mobo's
James Wilson
StephenOz
Post by StephenOz »
That is what I will be doing :)
Flash_
Post by Flash_ »
I've cured similar problems just by getting the most recent kernels. Although the NIC on one of my nvidia boards still doesn't work under linux. (Receives but doesn't send, not very useful!)
Takes a while for the linux guys to support the really new stuff, and Nvidia are one company who love to change specs and hardware on the fly. :(
collinm
Re: (Incombatibility) Asus A7N266-VM Motherboard
Post by collinm »
StephenOz wrote:Just some info for others. It seems the Asus A7N266-VM Motherboard has problems with Linux (nVidia nForce chipset).
post on nvnews web site
