Cordel, here is what I get. It looks like it has the correct modprobes to me:
bttv: driver version 0.9.16 loaded
bttv: using 32 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:02:0c.0, irq: 5, latency: 32, mmio: 0xe3000000
bttv0: using: Kodicom 4400R (slave) [card=133,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .<6>agpgart: Detected VIA Apollo Pro 133 chipset
bttv: Bt8xx card found (1).
bttv1: Bt878 (rev 17) at 0000:02:0d.0, irq: 6, latency: 32, mmio: 0xe2000000
bttv1: using: Kodicom 4400R (master) [card=132,insmod option]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: using tuner=-1
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
bttv2: Bt878 (rev 17) at 0000:02:0e.0, irq: 11, latency: 32, mmio: 0xe1000000
bttv2: using: Kodicom 4400R (slave) [card=133,insmod option]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: using tuner=-1
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (3).
bttv3: Bt878 (rev 17) at 0000:02:0f.0, irq: 10, latency: 32, mmio: 0xe0000000
bttv3: using: Kodicom 4400R (slave) [card=133,insmod option]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: using tuner=-1
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .<6>USB Universal Host Controller Interface driver v2.3
[<e146f7b7>] (bttv_irq+0x0/0x63e [bttv])
bttv0: timeout: drop=0 irq=1/1, risc=1dee503c, bits: VSYNC HSYNC OFLOW RISCI
bttv0: reset, reinitialize
bttv0: PLL: 28636363 => 35468950 . ok
bttv0: timeout: drop=0 irq=1/1, risc=1dee503c, bits: FMTCHG VSYNC HSYNC HLOCK VPRES RISCI
bttv0: timeout: drop=0 irq=1/1, risc=1dee503c, bits: VSYNC HSYNC RISCI
bttv0: timeout: drop=0 irq=1/1, risc=1dee503c, bits: FMTCHG VSYNC HSYNC RISCI
bttv0: timeout: drop=0 irq=1/1, risc=1dee501c, bits: VSYNC HSYNC RISCI
bttv0: timeout: drop=0 irq=1/1, risc=1dee501c, bits: FMTCHG VSYNC HSYNC RISCI
