ERR [Failed to set picture attributes: Invalid argument]
will
Post by will »
After fixing everyhting (log files, access, ...), I still get an error message in the /var/log/messages
Does anybody get that as well ? Do you have any clue how to fix it ???
Will
zoneminder
Site Admin
Re: ERR [Failed to set picture attributes: Invalid argument]
Post by zoneminder »
Do you know if you have STRICT_VIDEO_CONFIG set in your options? If so then it might be worth switching it off and seeing if that helps.
Regards,
Phil,
will
Post by will »
The current value is 0, it is the default value (I never changed that)
gessel
Post by gessel »
I get something similar
zmc-d0[2309]: ERR [Failed to set window attributes: Invalid argument]
Also STRICT_VIDEO_CONFIG is set to off (unchecked).
-David
zoneminder
Site Admin
You will still get the error even with STRICT_VIDEO_CONFIG off, it just won't treat it as fatal. Does everything else work?
Phil,
