Unable to run "/usr/local/bin/zmfix", output is &a
zakabog
Post by zakabog »
I try to start zoneminder with
zmpkg.pl start
It doesn't start and this is the only error I receive in the zmpkg log file
01/19/07 15:31:31.627028 zmpkg[3856].INF [Command: start]
01/19/07 15:31:32.487962 zmpkg[3856].ERR [Unable to run "/usr/local/bin/zmfix", output is ""]
I'm running Zoneminder 1.22.3
Linux version 2.6.19
gcc version 3.3.5
Debian 1:3.3.5-13 (debian unstable)
Oh I forgot to mention, I had installed it once before, it started and everything (or at least it said it was started) but when I clicked on the monitor I wanted to view it was a broken image. I fixed all the paths to point to the proper scripts but nothing worked, so I did
make uninstall
make clean
and then re-installed everything.
zoneminder
Site Admin
Post by zoneminder »
Can you run zmfix manually? Is there anything in your messages log?
Phil
merlinthemagic
hey
Post by merlinthemagic »
Im sure you are using 64bit version and added the
to your build.
In that case you will need to link "libswscale.so.0" and all other shared libs to the /usr/lib64 directory.
relevant again, when using 64 bit versions.
http://www.zoneminder.com/forums/viewtopic.php?p=41693
