ok,
after a bit of panic (cams images disappear totally) i remake all the "cam source" redefining zone and etc, and it work perfectly.
Also, very great work, the same CPU have a better grab capacity and much more events are caught (so maybe also some algorythm was improved?) and recorded.
So a standing ovation for you, cause now is much more better than before (1.22.0)
something i really missed (or maybe... something i have missed if already is on and i've not noticed it) is a page or a little resume of what filters are running on (maybe a sort of list of "filter at work")
also, the "running in background" ones, run also if i close the client webpage or run ONLY if i've the page open ?
(cause today i find 100% of space occupied... and it seem a bit strange to me, maybe i've done something stupid.. need to check)
p.s.
I notice that there is some translation error (in italian, my translation is the it_it1 if i remember) so in a couple of days (maybe.. some weeks) i will correct and resend you another version
Alessio
upgrading from 1.22.0 to 1.22.3 and some comments
Re: upgrading from 1.22.0 to 1.22.3 and some comments
Quote. Really great work...
>"filter at work")
I agree. I find a little bit tricky to understand which filters are working. I have the same
problem with disk at 100%. Zmfilter.log says (see a different thread near here):
16/01/2007 06:30:38.262715 zmfilter[26296].DBG [Found filter 'PurgeWhenFull']
omissis
16/01/2007 06:30:38.263776 zmfilter[26296].DBG [Checking filter 'PurgeWhenFull', delete]
Does the last line mean that events are deleted or the filter itself was discarded?
I understand YOU did the italian translation of zm.
I, as italian guy, found it very clear and complete
Thank you
roberto@occhiostanco.com
>"filter at work")
omissis
Thank you
mmm, appear that it's running the filter and that the function "delete" was active... now i can't check mine, but late in the morning i read my logsocchiostanco wrote:> So a standing ovation for you
>"filter at work")
omissis
and try to find if it's the same here.
grazie,> (in italian, my translation is the it_it1 if i remember) so in a couple of days (maybe.. some
Thank you
other 2 guys had translated before me, i try to reorganize and check and
correct some little errors, also adding the news sentences and (hope)
translating the pop-up help of the options (in future) this program is really
a great work, and for me as really useful, so i try to help with my little
cents..
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
