did anyone ever viewed zm with windows mobile 5?using the wifi and view it?or using a cellular line dialup to the zm server?
i am using is in the montage view and seems the images did not steam correctly, the image is still. can windows 5 IE view the live stream?
thanks.
windows mobile 5
I have just got an imate jamin and am currently writing a viewer. I have a working sample that can select 16 cameras and view single cams. Over wifi i get about 2 fps and over gprs i get about 0.25 fps. I have some threading issues and settings issues but i can send you a hard coded settings version if you let me know your ip settings etc. Or wait till i get round to finishing it
James Wilson
no im sorry i havnt even looked at for ages now. I will see if i can pull it up the priorty list
James Wilson
hint taken lads
James Wilson
lol
James Wilson
