... and maybe your events too.
I started seeing heavy load of my flat adsl router for hours!
I investigated the apache log files and found that google bots were scanning all my zm events and indexing all pictures!
Since zm needs they be in the web space (or linked from the web space)
this may be a relevant side effect.
Zm is a great sowftware and I think it could be better configured to leave events be stored outside the web space.
As a workaround I enabled (and suggest to) apache authentication (.htaccess files) for /var/www/zm
Thank You
Roberto
Google spiders are collecting all my images ....
- lazyleopard
Another option is to add a robots.txt file to your web root directory. A simple "go away" one looks like this:
User-agent: *
Disallow: /
Rick Hewett
but there must have been a link to you images folder to get it to start spidering or not?
James Wilson
Options to prevent this but only with search engines that obey the rules.
First is the robots file like lazyleopard mentioned which is the easiest.
Also you should set apache to not index your folders, this will help even more.
Here is an example, this is what I have my rpms set by default when they are installed. If you compare this to your apache config you will see that following options "index" which means to index your folders to allow browsing.
Just remove the index from your apache config or you can add the entry above if you adjust the paths accordingly. Make sure you make a backup of your original config before making changes.
Alias /zm "/usr/lib/zm/html/"
<Directory "/usr/lib/zm/html">
Options MultiViews FollowSymLinks
AllowOverride All
Order allow,deny
Allow from all
</Directory>
do you have auth off?
James Wilson
