Ooops, thanks for pointing that out.i did the exit 0 and it almost worked.. Had to do it do .prerm file too.
You shouldn't have to. However . . . I've just had a look in my mysql db, and it looks like I have zmuser hanging around from my original source install experiments.Then i reinstalled the zoneminder deb.. but...
debian1:/tmp# dpkg -i zoneminder_1.22.3-1_i386.deb
A seleccionar pacote anteriormente não seleccionado zoneminder
(Lendo a base de dados ... 18677 ficheiros e directórios actualmente instalados.)
A descompactar zoneminder (desde zoneminder_1.22.3-1_i386.deb) ...
A instalar zoneminder (1.22.3-1) ...
Starting ZoneMinder: DBI connect('database=zm;host=localhost','zmuser',...) failed: Access denied for user 'zmuser'@'localhost' (using password: YES) at /usr/share/perl5/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 45.
failure
invoke-rc.d: initscript zoneminder, action "start" failed.
dpkg: erro processando zoneminder (--install):
subprocesso post-installation script retornou erro do status de saída 255
Foram encontrados erros enquanto processava:
zoneminder
It seems you need to create a zmuser in mysql...
In summary: 'DOH!
Note to self: Test on CLEAN system. Note to self: Test on CLEAN system.
I'll do the very quick and dirty fix to that and update the packages, then I'll work out a cleaner fix.
