I can see still images from my cameras just find however i can not se no streaming video in any of my browers konqueror or internet explorer. but like i said i can see picture form the stills I hope i am just being stupid and overlooking something I have been working with this software all nite with suse 8.2 and all else has worked fine till this point.
thanks in advance
David Taylor
dat1356@yahoo.com
Cant see stream
Re: Cant see stream
Kind of obvious but....
You did download and place the cambozola applet in your /var/www/html/zm directory correct?
Not sure about Konqueror ( I can't get past the login screen with Konqueror in my setup for some reason ) but IE doesn't natively support image streaming.
Re: Cant see stream
I did download and put the cambozola.jar in the directory however i did not get ant to work to build cambozola with would the default files work ok?
also I don't get a first pic ether just a gray spot were there should be a video
Thanks in advance
david taylor
Thanks in advance
david taylor
- zoneminder
- Site Admin
- Contact:
Re: Cant see stream
Hi David,
The cambozola applet should work fine without being rebuilt. However there are issues with later versions so I would recommend trying v0.22 which you can get from the Downloads page here.
Regards,
Phil,
Regards,
Phil,
Re: Cant see stream
I have exactly the same problem. cambozola shows OK the test stream from cambozola-server (included with cambozola package), but there is no picture from zms.
zms streams in mozilla work fine. Tried with both cambozola 0.22 and cambozola-latest.
