FPS tweak
No idea... more details needed.
IP Camera? Analog with capture card? If so, what kind?
By "Start out at a high FPS" do you mean that it starts recording at a high FPS (and what is that FPS), and immediately goes down to the 4FPS you're seeing? Or does it only happen when it detects motion? Does it stay at the high FPS for any amount of time? Do you have a maximum and an alarm maximum FPS set?
Hopefully with enough information, maybe we can help you get the result you are looking for.
--Pathway
--Pathway
