The colour to check when detecting signal loss / camera
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
robi
Post by robi »
The colour to check when detecting signal loss should be a per monitor setting rather than a global option as it is now.
You may have a wide variety of cameras that give different colours on the same system. A bt8x8 card gives a blue, but some webcams have a shade of gray, IP cameras usually have black. This setting should be moved to Monitor settings > Misc tab, and individually saved for each.
zoneminder
Site Admin
Post by zoneminder »
Yes, this is planned for the next version along with a few other similar options.
Phil
