Backports used in Ubuntu Dapper install of ZM
- perspectoff
Thanks to Peter Howard for the Debian package in unstable at:
http://packages.debian.org/unstable/net/zoneminder
I installed ZoneMinder in Ubuntu Dapper (LAMP server) successfully for the first time using this package. Of course, I had to satisfy a lot of dependencies manually and use a lot of backports, as the package uses many newer modules than are available in Dapper.
Specifically, as mentioned in the Dapper wiki, I installed:
sudo apt-get install apache2 php5 php5-mysql libapache2-mod-auth-mysql mysql-server g++ \
make netpbm libssl-dev libjpeg62-dev libmime-perl libwww-perl libarchive-tar-perl \
libdate-manip-perl libarchive-zip-perl libmime-lite-perl libdbi-perl libdbd-mysql-perl \
libpcre3-dev libmysqlclient12-dev libcurl3-openssl-dev libjpeg-mmx-dev \
liblwp-protocol-http-socketunix-perl mc ffmpeg xawtv
(Note: I already had apache2 php5 php5-mysql as part of my LAMP server installation so I didn't need to install those. If you don't have a LAMP server, you obviously will need these).
Then I also installed (or obtained through Dapper's Synaptic Package Manager, which I generally prefer):
sudo apt-get install libdate-manip-perl libavcodec-dev libavformat-dev tzdata
(Note: libavcodec-dev and libavformat-dev handled the ogg, theora, dc1394 error problems.)
Then I had to install dependencies from a number of non-dapper sources (in all cases I first searched for an Ubuntu specific package at http://packages.ubuntu.com/ before accepting the Debian package):
It is possible to install downloaded packages from the Nautilus File Browser by clicking on them. This invokes the GDebi Package Installer to install them automatically. However, GDebi usually hides or reports errors in a cryptic manner. A better alternative is to use the command line terminal and dpkg -i. Using this command line terminal method (while logged in as root using sudo -s), it is easier to see error messages.
sudo -s
dpkg -i libc6_2.5-0ubuntu14_i386.deb (must be the ubuntu package)
(downloaded from http://packages.ubuntu.com/feisty/base/libc6)
dpkg -i libc6-i686_2.5-0ubuntu14_i386.deb
(downloaded from http://packages.ubuntu.com/feisty/libs/libc6-i686)
dpkg -i belocs-locales-bin_2.4-1ubuntu6_i386.deb
(downloaded from http://packages.ubuntu.com/feisty/misc/ ... ocales-bin)
dpkg -i locales_2.3.22_all.deb
(downloaded from http://packages.ubuntu.com/feisty/base/locales)
dpkg -i gcc-4.1-base_4.1.1-21_i386.deb (no other version will do)
(available at http://packages.debian.org/unstable/devel/gcc-4.1-base)
dpkg -i libgcc1_4.1.1-21_i386.deb (no other version will do)
(available at http://packages.debian.org/unstable/libs/libgcc1)
dpkg -i libstdc++6_4.1.1-21_i386.deb (no other version will do)
(available at http://packages.debian.org/unstable/libs/libstdc++6)
[Note: I also tried the three Ubuntu packages
dpkg -i gcc-4.1-base_4.1.2-0ubuntu4_i386.deb
(available at http://packages.ubuntu.com/feisty/libs/gcc-4.1-base)
dpkg -i libgcc1_4.1.2-0ubuntu4_i386.deb
(available at http://packages.ubuntu.com/feisty/libs/libgcc1)
libstdc++6_4.1.2-0ubuntu4_i386.deb
(available at http://packages.ubuntu.com/feisty/base/libstdc++6)
instead of the Debian packages, but they didn't seem to satisfy the ZoneMinder dependencies.]
dpkg -i mysql-common_5.0.38-0ubuntu1_all.deb
(available at http://packages.ubuntu.com/feisty/misc/mysql-common)
dpkg -i libmysqlclient15off_5.0.38-0ubuntu1_i386.deb
(available at http://packages.ubuntu.com/feisty/libs/ ... lient15off)
After these were all satisfied, I installed the zoneminder debian package:
dpkg -i zoneminder_1.2.3-4_i386.deb
Success.
For the database creation I used a slightly different method than in the wiki:
fido@zmserver:~$ sudo -s
root@zmserver:# mysqladmin -u zmusername -p create zmdatabase
(you can use any database name instead of zmdatabase, and any username that you have previously created. For example, I used
root@zmserver:# mysqladmin -u fido -p create zmdbase
root@zmserver:# mysql -u fido -p
(note: you must have fido set up as a mysql superuser to do this. If you have troubles, then use root as the mysql superuser, i.e.
root@zmserver:# mysql -u root -p )
(More information on mySQL initial privileges are at:
http://dev.mysql.com/doc/refman/5.0/en/ ... leges.html )
mysql> GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, INDEX, ALTER, CREATE TEMPORARY TABLES, LOCK TABLES ON zmdbase.* TO 'zmuser'@'localhost' IDENTIFIED BY 'password';
mysql> GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, INDEX, ALTER, CREATE TEMPORARY TABLES, LOCK TABLES ON zmdbase.* TO 'root'@'localhost' IDENTIFIED BY 'password';
(I used my usual passwords here. Also note that MySql commands end with a semicolon.)
mysql> quit
root@zmserver:# mysqladmin reload
These methods seemed to have avoided a lot of the errors others have written about in Dapper.
sudo -s
Success.
mysql> quit
- perspectoff
Warning: Using apt or Syn Pack Man for non-dapper depend's ?
The method noted worked fine for me. But I have to mention that installing the packages by hand does not allow aptitude or Synaptic Package Manager to manage the packages.
If someone knows how to install the listed non-dapper dependencies through the aptitude or Synapatic Package Manager system of repositories, I would appreciate it.
- perspectoff
updating libc6 to the feisty version
In case anyone comes across this associated problem, let me give you my solution.
I had libc6-dev installed as well as libc6.
libc6-dev must be the same version as libc6, or you will have a "broken" package.
libc6-dev in edgy and feisty depends on the module linux-libc-dev.
In dapper, though, libc6-dev depends on the older module linux-kernel-headers instead.
When you install the module linux-libc-dev, it will replace the module linux-kernel-headers.
Now, dapper will allow you to replace linux-kernel-headers with the edgy version of linux-libc-dev (linux-libc-dev_2.6.17.1-11.37_i386.deb) but not with the feisty version (linux-libc-dev_2.6.20-14.22_i386.deb).
Fortunately, the edgy version of linux-libc-dev (linux-libc-dev_2.6.17.1-11.37_i386.deb) will satisfy the feisty version of libc6-dev (libc6-dev_2.5-0ubuntu14_i386.deb).
So, if you have the misfortune of having installed libc6-dev somewhere along the way and now must upgrade libc6 to the feisty version in order to install ZoneMinder, then you must upgrade libc6-dev and linux-libc-dev as well, or you will have a broken system.
dpkg -i linux-libc-dev_2.6.17.1-11.37_i386.deb
(available at http://packages.ubuntu.com/edgy/devel/linux-libc-dev)
dpkg -i libc6-dev_2.5-0ubuntu14_i386.deb
(available at http://packages.ubuntu.com/feisty/libdevel/libc6-dev)
Well, this is just not a viable option. The convoluted backports mean that the system will never dist-upgrade smoothly. The main advantage of the package management system is upgrades, and that just staked it in the heart.
So... At this point it looks like Feisty with the tar.gz is the most stable install method? Or can a clean Edgy run the tar without extra packages? Does anyone know how the BlueCherry xubuntu Live CD does it?
Are backports used in the actual Ubuntu Dapper build of ZM?
I do maintain a build against dapper at ftp://www.northern-ridge.com.au/zoneminder, which should (among other things) not force you to use PHP5.perspectoff wrote:Thanks to Peter Howard for the Debian package in unstable at:
For those wondering about the ubuntu situation:
Feisty went into freeze before I had the package fully "shaken down". Given it's still not fully "shaken down", that's not surprising.
When I originally produced the package I was working exclusively on Ubuntu Dapper. Now that I've got VMware server running at home (well sort of, but that's another story) I'm building and testing against:
- Ubuntu Dapper
Ubunty Edgy
Debian Sid
So with continuing (appreciated) feedback, and continuing patience, dependency fun and other errors should be resolved "Real Soon Now(TM)".
Untill I (or someone else) produces a real package built against Feisty it's definitely the way to go there.Lee Sharp wrote:So... At this point it looks like Feisty with the tar.gz is the most stable install method?
PS: If you build it from tar.gz and don't get the "bad fd number" message on startup, please let me know (either here or by email). At the moment I'm assuming it's not specific to my packaging efforts which makes the searching slower.
RE:Feisty Fawn install
Good Day to ZoneMinder, I am about to install (or try) the ZoneMinder CCTV,
I know there is at least a few methods. I have the last Livedisc, but I had issues with installation where it simply stalled and did nothing.
Now I am reading you have a Deb unstable version, and it seems Ubuntu
can support it, great.
My question is, where exactly does Zoneminder install /usr, if so, can you assist me in determining my OS partitions.
Example in my usual installation as a desktop, a 150 gigs SATA hardrive
might be /root 4 gigs, /usr 12 gigs, /var 4 gigs, swap 2 gigs, and the rest /home.
So Should I make my USR partition extra big because it needs to run the cameras. Or is it possible to install ZoneMinder on /opt and dedicate an entire partition to it.
Once I know the direction I am taking for partitions, and installation, the start of this project will commence. I plan to install Feisty Fawn i386 alternate.
So, thank you in advance for your assistance.
Re: RE:Feisty Fawn install
First thing - don't use the debian package - I have .debs for Ubuntu (dapper and edgy) at ftp://www.northern-ridge.com.au/zonemidner/scorptig wrote:Good Day to ZoneMinder, I am about to install (or try) the ZoneMinder CCTV,
As the package installs it, the events and images go in /var/cache/zoneminder (linked to /usr/share/zoneminder), so I'd bump up /var and drop /usrMy question is, where exactly does Zoneminder install /usr, if so, can you assist me in determining my OS partitions.
Right now I haven't built an image for Feisty. If you don't mind being a bit of a "guinea pig", I can build it on the weekend and let you know when it's gone into the abovementioned FTP site.Once I know the direction I am taking for partitions, and installation, the start of this project will commence. I plan to install Feisty Fawn i386 alternate.
PJH
Feisty 7.04 Ubuntu ZM
Great, so I shall correct partitions to meet needs, I'll give you a hardware profile.
No problem with command lines, 4th year in Linux, I average testing 3 OS's a week,
I presently on my workstation boot, 5 Linux OS, I have a dedicated pc and 7 capture cards based on GeoVision.
Anyway, Yes, I'd love to test this weekend. I'll start by installing my base system
Ubuntu 7.04 alternate.
Get back to you soon.
Thanks Again. Should be fun.
Set-Up Partitions and did Install Ubuntu 7.04
OK, so far, no problem, for readers, I use Gparted, a LiveDisc Partition Editor, this permitted prior to install of Ubuntu to have partitions ready.
I have a SATA HDD Seagate, it's 160Higs but actually works out to a safe 150 Gigs available, I'll post a Hardware Info and post pre-install Zoneminder resume.
For now, I've set up my hard drive as follows:
My second purpose is to use Zoneminder with some existing hardware.
And possibility of scripting one or more cameras to embed into existing
web pages of a site, feeding/streaming video. I need access of this camera GUI, through an existing network, with secure access login.
My previous broadcasting experience may be usefull in set-up of cameras,
for correct Chroma and White Level setups. Motion Detection of course will
be an important function to set-up, along with many other parameters.
This installation will be a learning experience.
And the result, I feel with the Community support will be be beneficial to all. And the end product should be a template for future reference.
Now this is being done within a x86_32 architecture, I used ReiserFS for
file structure. We may get into other file types, if needed.
So, I'll get some more data ready to post on this installtion.
Thank You again.
- /root 6 gigs
/usr 18 gigs
/swap 2 gigs
my extended partition
/tmp 4 gigs
/home 12 gigs
/var 108 gigs
Thank You again.
Ubuntu 7.04 Feisty Fawn with ZoneMinder update hardware info
OK I generated a bit of data prior to this Zoneminder install.
Partitions % used prior to ZoneMinder install
hardinfo
System Info
System information report, generated by Sysinfo: 08/05/2007 9:36:55 AM
http://sysinfo.r8.org
The original CCTV hardware was GeoVision GV600 8 port, 7 cameras are used.
OK I am ready to proceed ahead.
webcam@videotron:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 5.9G 174M 5.7G 3% /
varrun 502M 104K 502M 1% /var/run
varlock 502M 0 502M 0% /var/lock
procbususb 502M 112K 502M 1% /proc/bus/usb
udev 502M 112K 502M 1% /dev
devshm 502M 0 502M 0% /dev/shm
lrm 502M 33M 469M 7% /lib/modules/2.6.20-15-generic/volatile
/dev/sda6 12G 33M 12G 1% /home
/dev/sda5 4.0G 33M 3.9G 1% /tmp
/dev/sda2 18G 1.5G 17G 9% /usr
/dev/sda7 108G 270M 108G 1% /var
Computer
Summary
Computer
Processor Intel(R) Celeron(R) CPU 3.06GHz
Memory 1027MB (450MB used)
Operating System Ubuntu 7.04
User Name webcam (webcam original)
Date/Time 05/08/07 / 09:37
Display
Resolution 1024x768 pixels
OpenGL Renderer Mesa DRI Intel(R) 865G 20061017 x86/MMX/SSE2
X11 Vendor The X.Org Foundation
Multimedia
Audio Adapter MPU-401 UART - MPU-401 UART
Audio Adapter ICH4 - Intel ICH5
Processor
Processor
Name Pentium 4
Specification Intel(R) Celeron(R) CPU 3.06GHz
Family, model, stepping 15, 4, 1
Vendor GenuineIntel
Cache Size 256kb
Frequency 3068.98MHz
BogoMips 6142.18
Byte Order Little Endian
Features
FDIV Bug no
HLT Bug no
F00F Bug no
Coma Bug no
Has FPU yes
Capabilities
fpu Floating Point Unit
vme Virtual 86 Mode Extension
de Debug Extensions - I/O breakpoints
pse Page Size Extensions (4MB pages)
tsc Time Stamp Counter and RDTSC instruction
msr Model Specific Registers
pae Physical Address Extensions (36-bit address, 2MB pages)
mce Machine Check Architeture
cx8 CMPXCHG8 instruction
apic Advanced Programmable Interrupt Controller
sep Fast System Call (SYSENTER/SYSEXIT instructions)
mtrr Memory Type Range Registers
pge Page Global Enable
mca Machine Check Architecture
cmov Conditional Move instruction
pat Page Attribute Table
pse36 36bit Page Size Extensions
clflush Cache Line Flush instruction
dts Debug Store
acpi Thermal Monitor and Software Controlled Clock Facilities
mmx MMX technology
fxsr FXSAVE and FXRSTOR instructions
sse SSE instructions
sse2 SSE2 (WNI) instructions
ss Self Snoop
ht HyperThreading
tm Thermal Monitor
pb Pending Break Enable
Operating System
Version
Kernel Linux 2.6.20-15-generic (i686)
Compiled #2 SMP Sun Apr 15 07:36:31 UTC 2007
C Library GNU C Library version 2.5 (stable)
Distribution Ubuntu 7.04
Current Session
Computer Name videotron
Home Directory /home/webcam
Desktop Environment GNOME 92.-1253061137 (session name: Default)
Misc
Uptime 4 days, 0 hour and 40 minutes
Load Average 0.11, 0.40, 0.26
Languages
Available Languages
en_AU.utf8 English locale for Australia
en_BW.utf8 English locale for Botswana
en_CA.utf8 English locale for Canada
en_DK.utf8 English locale for Denmark
en_GB.utf8 English locale for Britain
en_HK.utf8 English locale for Hong Kong
en_IE.utf8 English locale for Ireland
en_IN English language locale for India
en_NZ.utf8 English locale for New Zealand
en_PH.utf8 English language locale for Philippines
en_SG.utf8 English language locale for Singapore
en_US.utf8 English locale for the USA
en_ZA.utf8 English locale for South Africa
Sensors
Filesystems
Mounted File Systems
/dev/sda1 5.9 GiB total, 5.7 GiB free
proc 0.0 B total, 0.0 B free
/sys 0.0 B total, 0.0 B free
varrun 501.7 MiB total, 501.6 MiB free
varlock 501.7 MiB total, 501.7 MiB free
procbususb 501.7 MiB total, 501.5 MiB free
udev 501.7 MiB total, 501.5 MiB free
devshm 501.7 MiB total, 501.7 MiB free
devpts 0.0 B total, 0.0 B free
lrm 501.7 MiB total, 468.7 MiB free
/dev/sda6 11.7 GiB total, 11.7 GiB free
/dev/sda5 3.9 GiB total, 3.9 GiB free
/dev/sda2 17.6 GiB total, 16.1 GiB free
/dev/sda7 108.0 GiB total, 107.7 GiB free
binfmt_misc 0.0 B total, 0.0 B free
Shared Directories
SAMBA
NFS
Display
Display
Version 7.2.0
Monitors
Monitor 0 1024x768 pixels
Extensions
BIG-REQUESTS
Composite
DAMAGE
DPMS
Extended-Visual-Information
GLX
MIT-SCREEN-SAVER
MIT-SHM
MIT-SUNDRY-NONSTANDARD
RANDR
RENDER
SECURITY
SGI-GLX
SHAPE
SYNC
TOG-CUP
X-Resource
XAccessControlExtension
XC-APPGROUP
XC-MISC
XFIXES
XFree86-Bigfont
XFree86-DGA
XFree86-DRI
XFree86-Misc
XFree86-VidModeExtension
XInputExtension
XKEYBOARD
XTEST
XVideo
OpenGL
Vendor Tungsten Graphics, Inc
Version 1.3 Mesa 6.5.2
Network Interfaces
Network Interfaces
lo Sent 0.00MiB, received 0.00MiB
eth0 Sent 0.75MiB, received 34.32MiB
Users
Human Users
webcam webcam original
System Users
root root
daemon daemon
bin bin
sys sys
sync sync
games games
man man
lp lp
mail mail
news news
uucp uucp
proxy proxy
www-data www-data
backup backup
list Mailing List Manager
irc ircd
gnats Gnats Bug-Reporting System (admin)
nobody nobody
dhcp
syslog
klog
messagebus
avahi-autoipd Avahi autoip daemon
avahi Avahi mDNS daemon
cupsys
haldaemon Hardware abstraction layer
hplip HPLIP system user
gdm Gnome Display Manager
Devices
Kernel Modules
Loaded Modules
isofs
udf Universal Disk Format Filesystem
nls_iso8859_1
nls_cp437
vfat VFAT filesystem support
fat
usb_storage USB Mass Storage driver for Linux
libusual
ipv6 IPv6 protocol stack for Linux
binfmt_misc
rfcomm Bluetooth RFCOMM ver 1.8
l2cap Bluetooth L2CAP ver 2.8
bluetooth Bluetooth Core ver 2.11
i915 Intel Graphics
drm DRM shared core routines
ppdev
speedstep_lib Library for Intel SpeedStep 1 or 2 cpufreq drivers.
cpufreq_powersave CPUfreq policy governor 'powersave'
cpufreq_stats 'cpufreq_stats' - A driver to export cpufreq statsthrough sysfs filesystem
cpufreq_userspace CPUfreq policy governor 'userspace'
cpufreq_ondemand 'cpufreq_ondemand' - A dynamic cpufreq governor for Low Latency Frequency Transition capable processors
cpufreq_conservative 'cpufreq_conservative' - A dynamic cpufreq governor for Low Latency Frequency Transition capable processors optimised for use in a battery environment
freq_table CPUfreq frequency table helpers
tc1100_wmi ACPI WMI Driver
pcc_acpi ACPI HotKey driver for Panasonic Let's Note laptops
sony_acpi ACPI Sony Notebook Control Driver v0.2
dev_acpi Device file access to ACPI namespace
video ACPI Video Driver
battery ACPI Battery Driver
container ACPI container driver
sbs Smart Battery System ACPI interface driver
button ACPI Button Driver
i2c_ec ACPI EC SMBus driver
dock ACPI Dock Station Driver
ac ACPI AC Adapter Driver
asus_acpi Asus Laptop ACPI Extras Driver
backlight Backlight Lowlevel Control Abstraction
lp
snd_intel8x0 Intel 82801AA,82901AB,i810,i820,i830,i840,i845,MX440; SiS 7012; Ali 5455
snd_ac97_codec Universal interface for Audio Codec '97
ac97_bus
snd_pcm_oss PCM OSS emulation for ALSA.
snd_mixer_oss Mixer OSS emulation for ALSA.
snd_pcm Midlevel PCM code for ALSA.
snd_seq_dummy ALSA sequencer MIDI-through client
snd_seq_oss OSS-compatible sequencer module
snd_seq_midi Advanced Linux Sound Architecture sequencer MIDI synth.
snd_seq_midi_event MIDI byte <-> sequencer event coder
bt878
bttv bttv - v4l/v4l2 driver module for bt848/878 based cards
video_buf helper module to manage video4linux pci dma buffers
ir_common
compat_ioctl32
i2c_algo_bit I2C-Bus bit-banging algorithm
btcx_risc some code shared by bttv and cx88xx drivers
snd_mpu401 MPU-401 UART
snd_mpu401_uart Routines for control of MPU-401 in UART mode
snd_rawmidi Midlevel RawMidi code for ALSA.
tveeprom i2c Hauppauge eeprom decoder driver
i2c_core I2C-Bus main module
videodev Device registrar for Video4Linux drivers v2
v4l2_common misc helper functions for v4l2 device drivers
v4l1_compat v4l(1) compatibility layer for v4l2 drivers.
analog Analog joystick and gamepad driver
gameport Generic gameport layer
snd_seq Advanced Linux Sound Architecture sequencer.
snd_timer ALSA timer interface
snd_seq_device ALSA sequencer device management
snd Advanced Linux Sound Architecture driver for soundcards.
soundcore Core sound module
iTCO_wdt Intel TCO WatchDog Timer Driver
iTCO_vendor_support Intel TCO Vendor Specific WatchDog Timer Driver Support
psmouse PS/2 mouse driver
shpchp Standard Hot Plug PCI Controller Driver
pci_hotplug PCI Hot Plug PCI Core
snd_page_alloc Memory allocator for ALSA system.
pcspkr PC Speaker beeper driver
serio_raw Raw serio driver
parport_pc PC-style parallel port driver
parport
intel_agp
agpgart AGP GART driver
af_packet
tsdev Input driver to touchscreen converter
evdev Input driver event char devices
reiserfs ReiserFS journaled filesystem
sg SCSI generic (sg) driver
sd_mod SCSI disk (sd) driver
sr_mod SCSI cdrom (sr) driver
cdrom
8139cp RealTek RTL-8139C+ series 10/100 PCI Ethernet driver
generic PCI driver module for generic PCI IDE
usbhid USB HID core driver
hid
ata_piix SCSI low-level driver for Intel PIIX/ICH ATA controllers
8139too RealTek RTL-8139 Fast Ethernet driver
mii MII hardware support library
ata_generic low-level driver for generic ATA
libata Library module for ATA devices
scsi_mod SCSI core
ehci_hcd 10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver
uhci_hcd USB Universal Host Controller Interface driver
usbcore
thermal ACPI Thermal Zone Driver
processor ACPI Processor Driver
fan ACPI Fan Driver
fbcon
tileblit Tile Blitting Operation
font Console Fonts
bitblit Bit Blitting Operation
softcursor Generic software cursor
vesafb
capability Standard Linux Capabilities Security Module
commoncap Standard Linux Common Capabilities Security Module
PCI Devices
PCI Devices
Host bridge Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface
VGA compatible controller Intel Corporation 82865G Integrated Graphics Controller
USB Controller Intel Corporation 82801EB/ER
PCI bridge Intel Corporation 82801 PCI Bridge
ISA bridge Intel Corporation 82801EB/ER
IDE interface Intel Corporation 82801EB/ER
SMBus Intel Corporation 82801EB/ER
Multimedia audio controller Intel Corporation 82801EB/ER
Multimedia video controller Brooktree Corporation Bt878 Video Capture
Multimedia controller Brooktree Corporation Bt878 Audio Capture
Ethernet controller Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+
USB Devices
EHCI Host Controller
UHCI Host Controller
USB-PS/2 Optical Mouse
Printers
Printers
Input Devices
Input Devices
Macintosh mouse button emulation
AT Translated Set 2 keyboard
PC Speaker
Power Button (FF)
Power Button (CM)
Logitech USB-PS/2 Optical Mouse
Storage
IDE Disks
SCSI Disks
HL-DT-ST CD-RW GCE-8525B
ATA ST3160815AS
Benchmarks
CPU ZLib
Error
ZLib not found
CPU Fibonacci
Results (in seconds; lower is better)
This Machine 0.00
AMD Athlon XP 3200+ 6.64
Intel Celeron M 1.5GHz 11.10
CPU MD5
This Machine 5.77
Intel Celeron M 1.5GHz 3.42
AMD Athlon XP 3200+ 5.04
CPU SHA1
This Machine 5.07
AMD Athlon XP 3200+ 4.88
Intel Celeron M 1.5GHz 5.50
CPU Blowfish
This Machine 18.47
SYSTEM INFORMATION
Running Ubuntu Linux, the 4.0 release.
GNOME: 2.18.1 (Ubuntu 2007-04-10)
Kernel version: 2.6.20-15-generic (#2 SMP Sun Apr 15 07:36:31 UTC 2007)
GCC: 4.1.2 (i486-linux-gnu)
Xorg: 7.2.0 (04 April 2007)
Hostname: videotron
Uptime: 4 days 0 h 39 min
CPU INFORMATION
GenuineIntel, Intel(R) Celeron(R) CPU 3.06GHz
Number of CPUs: 1
CPU clock currently at 3068.982 MHz with 256 KB cache
Numbering: family(15) model(4) stepping(1)
Bogomips: 6142.18
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe lm constant_tsc up pni monitor ds_cpl tm2 cid cx16 xtpr
MEMORY INFORMATION
Total memory: 1003 MB
Total swap: 2047 MB
STORAGE INFORMATION
SCSI device - scsi0
Vendor: HL-DT-ST
Model: CD-RW GCE-8525B
SCSI device - scsi3
Vendor: ATA
Model: ST3160815AS
HARDWARE INFORMATION
MOTHERBOARD
Host bridge
Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
Subsystem: ASUSTeK Computer Inc. P5P800-MX Mainboard
PCI bridge(s)
Intel Corporation 82801 PCI Bridge (rev c2) (prog-if 00 [Normal decode])
USB controller(s)
Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 (rev 02) (prog-if 00 [UHCI])
Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 (rev 02) (prog-if 00 [UHCI])
Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 (rev 02) (prog-if 00 [UHCI])
Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 (rev 02) (prog-if 00 [UHCI])
Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller (rev 02) (prog-if 20 [EHCI])
ISA bridge
Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge (rev 02)
IDE interface
Intel Corporation 82801EB (ICH5) SATA Controller (rev 02) (prog-if 8f [Master SecP SecO PriP PriO])
Subsystem: ASUSTeK Computer Inc. P4P800 SE Mainboard
GRAPHIC CARD
VGA controller
Intel Corporation 82865G Integrated Graphics Controller (rev 02) (prog-if 00 [VGA])
SOUND CARD
Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev 02)
NETWORK
Ethernet controller
Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
OK Good Day Peter, I triedPeterHoward wrote:First thing - don't use the debian package - I have .debs for Ubuntu (dapper and edgy) at ftp://www.northern-ridge.com.au/zonemidner/scorptig wrote:Good Day to ZoneMinder, I am about to install (or try) the ZoneMinder CCTV,
So Should I make my USR partition extra big because it needs to run the cameras. Or is it possible to install ZoneMinder on /opt and dedicate an entire partition to it.Right now I haven't built an image for Feisty. If you don't mind being a bit of a "guinea pig", I can build it on the weekend and let you know when it's gone into the abovementioned FTP site.Once I know the direction I am taking for partitions, and installation, the start of this project will commence. I plan to install Feisty Fawn i386 alternate.
PJH
your ftp is down I am ready to test this, see my last posting of data.
I'll check back tonight.
