I enabled the athentification, and now i can't log in any more. I thought the user and pwd is zmuser and zmpass, but it doesn't work.
I installed Zoneminder on Ubuntu 6.10 acording this instrucitons:
http://www.zoneminder.com/wiki/index.ph ... _Alternate
Is there something wrong with the login, or is there a different user/pwd? Can I reset it somehow?
Thanks,
Robert
Help! Locked myself out :-(
Extracted from ZM Manual (available under 'Documentation'):
"Running in authenticated mode is recommended if your system is open to the internet at all. During installation a fully privileged user ‘admin’ has been created with a password also of ‘admin’. If you are using authentication you should change this password as soon as possible."
