Box has recently started freezing
Hi I am using Cordels v1.21.3 distribution and have had it running for a while. Shortly after I installed some updates related to daylight savings time and configured for no-ip.com, the machine started freezing at seemingly random times. Sometimes while i was logged in in the middle of an ssh session. I removed the no-ip configuration, but that has not resolved the issue. I have looked in the system log and not seen anything obvious (not that I really know what to look for). Is there some other log to look at? I was going to reinstall, but that would take me back to the old daylight savings time problem. Any suggestions?
On this one Flash_ is (umm.. being non gender specific) THE person! I pulled the cover off the case and let it sit over night, booted it up the next morning, and has been running happily for a day without freezing and without the cover. I apparently have some case cooling issues! I was running the box without the cover most of the time I was building it, so I guess around the same time I did the timezone upgrade, I also decided to put the cover on it.Flash_ wrote: I'm thinking hardware issue, getting too hot, bad drives, bad memory ...
I have a 2U case with 2 good fans in the front, a fan in the power supply (that blows into the case) and a empty spot for a fan in the back. I'm going to install a fan there and have it blow air out of the case from the back. I think I will also try one of those fans that fit in a pci slot to cool the video card which gets very warm. If that doesn't do it, I have another fan I may mount on the top part of the case near the drives.
