Zoneminder Feisty Fawn Ubuntu 7.0.4
oslick
Post by oslick »
There are two .deb packages on the zoneminder site. One for draper one for edgy. Can I use these for the newer Feisty Fawn, or should I compile it myself
PeterHoward
Post by PeterHoward »
You're the second person to ask today :)
Feel free to build it yourself, otherwise I hope to build (and do "sanity-check" testing only) for Feisty over the weekend.
John Williams
Post by John Williams »
I just did a fresh install on a new feisty install with the latest edgy zm deb. Worked fine, with a simple workaround. See the wiki, where I updated it with instructions for feisty... I did not include camera info, since that can be situation specific. I am running a cheapo BT878 card and can give additional info on how to get that running.
Let me know if it needs amplification...
John
PeterHoward
John Williams wrote:I just did a fresh install on a new feisty install with the latest edgy zm deb. Worked fine, with a simple workaround. See the wiki, where I updated it with instructions for feisty... I did not include camera info, since that can be situation specific. I am running a cheapo BT878 card and can give additional info on how to get that running.
If the workaround was the reconfigure of /bin/sh from dash to bash, then I'm concerned. One of the main points of my -6 release was to get things working with dash. Can you tell me what errors you were getting?
PJH
John Williams
Did a re-test on Feisty and the dash fix is working, so updated the wiki. Only workaround now is to change nph_zms to zms so that I get reliable streaming for localhost., and I had to add www_data to the video group to allow access without chmod every reboot.
BTW, running Xen on feisty so real easy to boot guest edgy and feisty versions to test stuff...
John
