Again all:
Quote of 'xawtv -hwscan':
-bash: xawtv: command not found
Quote of 'scanpci -v':
pci bus 0x0000 cardnum 0x00 function 0x00: vendor 0x1106 device 0x3123
VIA Technologies, Inc. VT8623 [Apollo CLE266]
CardVendor 0x1106 card 0xaa01 (VIA Technologies, Inc., Card unknown)
STATUS 0x2230 COMMAND 0x0006
CLASS 0x06 0x00 0x00 REVISION 0x00
BIST 0x00 HEADER 0x00 LATENCY 0x08 CACHE 0x00
BASE0 0xd0000008 addr 0xd0000000 MEM PREFETCHABLE
BYTE_0 0x00 BYTE_1 0x18 BYTE_2 0x88 BYTE_3 0x80
pci bus 0x0000 cardnum 0x01 function 0x00: vendor 0x1106 device 0xb091
VIA Technologies, Inc. VT8633 [Apollo Pro266 AGP]
STATUS 0xa230 COMMAND 0x0107
CLASS 0x06 0x04 0x00 REVISION 0x00
HEADER 0x01 LATENCY 0x00
PRIBUS 0x00 SECBUS 0x01 SUBBUS 0x01
SECLT 0x00 SECSTATUS 0xa220
IOBASE 0xf000 IOLIM 0x0fff
NOPREFETCH_MEMBASE 0xdc000000 MEMLIM 0xddffffff
PREFETCH_MEMBASE 0xd8000000 MEMLIM 0xdbffffff
NO_FAST_B2B NO_SEC_BUS_RST NO_M_ABRT VGA_EN ISA_EN NO_SERR_EN NO_PERR_EN
pci bus 0x0000 cardnum 0x0d function 0x00: vendor 0x1106 device 0x3044
VIA Technologies, Inc. IEEE 1394 Host Controller
STATUS 0x0210 COMMAND 0x0007
CLASS 0x0c 0x00 0x10 REVISION 0x80
BIST 0x00 HEADER 0x00 LATENCY 0x20 CACHE 0x08
BASE0 0xde000000 addr 0xde000000 MEM
BASE1 0x0000d001 addr 0x0000d000 I/O
MAX_LAT 0x20 MIN_GNT 0x00 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0000 cardnum 0x10 function 0x00: vendor 0x1106 device 0x3038
VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
CLASS 0x0c 0x03 0x00 REVISION 0x80
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x08
BASE4 0x0000d401 addr 0x0000d400 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x01 INT_LINE 0x0b
BYTE_0 0x40 BYTE_1 0x12 BYTE_2 0x03 BYTE_3 0x00
pci bus 0x0000 cardnum 0x10 function 0x01: vendor 0x1106 device 0x3038
BASE4 0x0000d801 addr 0x0000d800 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x02 INT_LINE 0x0a
pci bus 0x0000 cardnum 0x10 function 0x02: vendor 0x1106 device 0x3038
BASE4 0x0000dc01 addr 0x0000dc00 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x03 INT_LINE 0x05
pci bus 0x0000 cardnum 0x10 function 0x03: vendor 0x1106 device 0x3104
VIA Technologies, Inc. USB 2.0
STATUS 0x0210 COMMAND 0x0017
CLASS 0x0c 0x03 0x20 REVISION 0x82
BASE0 0xde001000 addr 0xde001000 MEM
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x04 INT_LINE 0x0b
BYTE_0 0x00 BYTE_1 0x02 BYTE_2 0x03 BYTE_3 0x00
pci bus 0x0000 cardnum 0x11 function 0x00: vendor 0x1106 device 0x3177
VIA Technologies, Inc. VT8235 ISA Bridge
STATUS 0x0210 COMMAND 0x0087
CLASS 0x06 0x01 0x00 REVISION 0x00
BIST 0x00 HEADER 0x80 LATENCY 0x00 CACHE 0x00
BYTE_0 0x45 BYTE_1 0x00 BYTE_2 0xf0 BYTE_3 0x00
pci bus 0x0000 cardnum 0x11 function 0x01: vendor 0x1106 device 0x0571
VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE
STATUS 0x0290 COMMAND 0x0007
CLASS 0x01 0x01 0x8a REVISION 0x06
BIST 0x00 HEADER 0x00 LATENCY 0x20 CACHE 0x00
BASE4 0x0000e001 addr 0x0000e000 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x01 INT_LINE 0xff
BYTE_0 0x1b BYTE_1 0xf2 BYTE_2 0x09 BYTE_3 0x05
pci bus 0x0000 cardnum 0x11 function 0x05: vendor 0x1106 device 0x3059
VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller
STATUS 0x0210 COMMAND 0x0001
CLASS 0x04 0x01 0x00 REVISION 0x50
BIST 0x00 HEADER 0x00 LATENCY 0x00 CACHE 0x00
BASE0 0x0000e401 addr 0x0000e400 I/O
BYTE_0 0x01 BYTE_1 0xcd BYTE_2 0x00 BYTE_3 0x00
pci bus 0x0000 cardnum 0x12 function 0x00: vendor 0x1106 device 0x3065
VIA Technologies, Inc. VT6102 [Rhine-II]
CardVendor 0x1106 card 0x0102 (VIA Technologies, Inc. VT6102 [Rhine II] Embeded Ethernet Controller on VT8235)
CLASS 0x02 0x00 0x00 REVISION 0x74
BASE0 0x0000ec01 addr 0x0000ec00 I/O
BASE1 0xde002000 addr 0xde002000 MEM
MAX_LAT 0x08 MIN_GNT 0x03 INT_PIN 0x01 INT_LINE 0x0b
BYTE_0 0x01 BYTE_1 0x00 BYTE_2 0x02 BYTE_3 0xfe
pci bus 0x0000 cardnum 0x14 function 0x00: vendor 0x109e device 0x036e
Brooktree Corporation Bt878 Video Capture
STATUS 0x8290 COMMAND 0x0006
CLASS 0x04 0x00 0x00 REVISION 0x11
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x00
BASE0 0xde003008 addr 0xde003000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0000 cardnum 0x14 function 0x01: vendor 0x109e device 0x0878
Brooktree Corporation Bt878 Audio Capture
CLASS 0x04 0x80 0x00 REVISION 0x11
BASE0 0xde004008 addr 0xde004000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0001 cardnum 0x00 function 0x00: vendor 0x1106 device 0x3122
VIA Technologies, Inc. VT8623 [Apollo CLE266] integrated CastleRock graphics
STATUS 0x0230 COMMAND 0x0007
CLASS 0x03 0x00 0x00 REVISION 0x03
BASE0 0xd8000008 addr 0xd8000000 MEM PREFETCHABLE
BASE1 0xdc000000 addr 0xdc000000 MEM
MAX_LAT 0x00 MIN_GNT 0x02 INT_PIN 0x01 INT_LINE 0x0b
Quote of 'scanpci':
Quote of 'zmu -d /dev/video0 -q -v':
Video Capabilities
Name: BT878 video (GrandTec Multi Cap
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 640
Height: 480
Picture Attributes
Palette: 7 - YUV422 capture
Colour Depth: 16
Brightness: 32896
Hue: 32896
Colour :33026
Contrast: 35090
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Quote of 'dmesg | grep bttv':
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:00:14.0, irq: 10, latency: 32, mmio: 0xde003000
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv0: PLL can sleep, using XTAL (28636363).
bttv0: OCERR @ 0362701c,bits: HSYNC OCERR*
bttv0: timeout: drop=7 irq=139777/139777, risc=07510024, bits: HSYNC FDSR
bttv0: reset, reinitialize
bttv0: timeout: drop=14 irq=345431/345431, risc=0155b024, bits: HSYNC FDSR
Quote of 'lspci -v':
00:00.0 Host bridge: VIA Technologies, Inc. VT8623 [Apollo CLE266]
Subsystem: VIA Technologies, Inc. Unknown device aa01
Flags: bus master, 66MHz, medium devsel, latency 8
Memory at d0000000 (32-bit, prefetchable)
Capabilities: [a0] AGP version 2.0
Capabilities: [c0] Power Management version 2
00:01.0 PCI bridge: VIA Technologies, Inc. VT8633 [Apollo Pro266 AGP] (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, medium devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: dc000000-ddffffff
Prefetchable memory behind bridge: d8000000-dbffffff
Capabilities: [80] Power Management version 2
00:0d.0 FireWire (IEEE 1394): VIA Technologies, Inc. IEEE 1394 Host Controller (rev 80) (prog-if 10 [OHCI])
Subsystem: VIA Technologies, Inc. IEEE 1394 Host Controller
Flags: bus master, medium devsel, latency 32, IRQ 10
Memory at de000000 (32-bit, non-prefetchable)
I/O ports at d000
Capabilities: [50] Power Management version 2
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80) (prog-if 00 [UHCI])
Subsystem: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
Flags: bus master, medium devsel, latency 32, IRQ 11
I/O ports at d400
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80) (prog-if 00 [UHCI])
I/O ports at d800
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 32, IRQ 5
I/O ports at dc00
00:10.3 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 82) (prog-if 20 [EHCI])
Subsystem: VIA Technologies, Inc. USB 2.0
Memory at de001000 (32-bit, non-prefetchable)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8235 ISA Bridge
Flags: bus master, stepping, medium devsel, latency 0
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06) (prog-if 8a [Master SecP PriP])
I/O ports at e000
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 50)
Flags: medium devsel, IRQ 5
I/O ports at e400
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 74)
Subsystem: VIA Technologies, Inc. VT6102 [Rhine II] Embeded Ethernet Controller on VT8235
I/O ports at ec00
Memory at de002000 (32-bit, non-prefetchable) [size=256]
Capabilities: [40] Power Management version 2
00:14.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at de003000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
00:14.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at de004000 (32-bit, prefetchable) [size=4K]
01:00.0 VGA compatible controller: VIA Technologies, Inc. VT8623 [Apollo CLE266] integrated CastleRock graphics (rev 03) (prog-if 00 [VGA])
Subsystem: VIA Technologies, Inc. VT8623 [Apollo CLE266] integrated CastleRock graphics
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 11
Memory at d8000000 (32-bit, prefetchable) [size=64M]
Memory at dc000000 (32-bit, non-prefetchable) [size=16M]
[virtual] Expansion ROM at dd000000 [disabled] [size=64K]
Capabilities: [60] Power Management version 2
Capabilities: [70] AGP version 2.0
Quote of 'lspci -n':
00:00.0 Class 0600: 1106:3123
00:01.0 Class 0604: 1106:b091
00:0d.0 Class 0c00: 1106:3044 (rev 80)
00:10.0 Class 0c03: 1106:3038 (rev 80)
00:10.1 Class 0c03: 1106:3038 (rev 80)
00:10.2 Class 0c03: 1106:3038 (rev 80)
00:10.3 Class 0c03: 1106:3104 (rev 82)
00:11.0 Class 0601: 1106:3177
00:11.1 Class 0101: 1106:0571 (rev 06)
00:11.5 Class 0401: 1106:3059 (rev 50)
00:12.0 Class 0200: 1106:3065 (rev 74)
00:14.0 Class 0400: 109e:036e (rev 11)
00:14.1 Class 0480: 109e:0878 (rev 11)
01:00.0 Class 0300: 1106:3122 (rev 03)
Quote of 'lspci':
