I restart installation!
-I have installed Debian 4.0
-edit /etc/apt/source.list with unstable version
-apt-get update
-apt-get install zoneminder
Lettura della lista dei pacchetti in corso... Fatto
Generazione dell'albero delle dipendenze in corso... Fatto
I seguenti pacchetti verranno inoltre installati:
apache2-mpm-prefork apache2-utils apache2.2-common ffmpeg liba52-0.7.4
libapache2-mod-php5 libapr1 libaprutil1 libasound2 libavcodec0d
libavformat0d libc6 libc6-i686 libconvert-binhex-perl libdate-manip-perl
libdbd-mysql-perl libdbi-perl libdc1394-13 libdirectfb-0.9-25 libexpat1
libgsm1 libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
libio-stringy-perl libjpeg62 libkeyutils1 libkrb53 libmailtools-perl
libmime-perl libmysqlclient15off libnet-daemon-perl libogg0 libplrpc-perl
libpq5 libraw1394-8 libsdl1.2debian libsdl1.2debian-alsa libsqlite3-0
libsvga1 libsysfs2 libtimedate-perl liburi-perl libvorbis0a libvorbisenc2
libwww-perl libxml2 libzzip-0-12 locales mysql-client-5.0 mysql-common
mysql-server mysql-server-5.0 php4-common php5 php5-common php5-mysql psmisc
svgalibg1 tzdata
Pacchetti suggeriti:
php-pear libasound2-plugins glibc-doc dbishell krb5-doc krb5-user
libcompress-zlib-perl libraw1394-doc libio-socket-ssl-perl tinyca
Pacchetti raccomandati:
libhtml-format-perl xml-core
I seguenti pacchetti NUOVI (NEW) saranno installati:
libavformat0d libconvert-binhex-perl libdate-manip-perl libdbd-mysql-perl
libdbi-perl libdc1394-13 libdirectfb-0.9-25 libexpat1 libgsm1
libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl libio-stringy-perl
libjpeg62 libkeyutils1 libmailtools-perl libmime-perl libmysqlclient15off
libnet-daemon-perl libogg0 libplrpc-perl libpq5 libraw1394-8 libsdl1.2debian
libsdl1.2debian-alsa libsqlite3-0 libsvga1 libsysfs2 libtimedate-perl
liburi-perl libvorbis0a libvorbisenc2 libwww-perl libxml2 libzzip-0-12
mysql-client-5.0 mysql-common mysql-server mysql-server-5.0 php4-common php5
php5-common php5-mysql psmisc svgalibg1 zoneminder
I seguenti pacchetti saranno aggiornati:
libc6 libc6-i686 libkrb53 locales tzdata
5 aggiornati, 56 installati, 0 da rimuovere e 100 non aggiornati.
à necessario prendere 58,4MB/59,4MB di archivi.
Dopo l'estrazione, verranno occupati 130MB di spazio su disco.
Continuare [S/n]?
at term apt-get apache and zoneminder start automatically
If I go to
http://IP it redirect to
http://IP/apache2-default/ and it print "it works!".
-ln -s /etc/zm/apache.conf /etc/apache2/conf.d/zm.conf
-/etc/init.d/apache2 reload
http://IP/zm
okay it work...very well!
If you want use this like howto!!
Still one problem.
View image (with livecd it work very well with this configuration)
How I can find a problem?thank you
