Upgrade ZM 1.22.2 to 1.22.3
Hello, please can you help me.
You may be are going to tell me " this topic allready exist " go and read it.
I did, but it do not work. The URL is not working anymore, this one :
http://www.fairpoint.net/~rdmelin/RPMS/ ... k.i586.rpm
My situation is : I have loaded ZM 1.22.2 form LiveCD to my HD. OK it is working.While i'am working into ZM-Console, a windows open saying "an update to ZoneMinder is available. The latest release is 1.22.3, you have V1.22.2. i lick on APPLY it run me to ZoneMinder.com
Ok, if what i did is right, i go to download section, and on the first download line, " Release 1.22.3 23rd November 2006" i clik on ALT1 or ALT2 to download the file.
Is is correct ?
That's what i did.
With guest-Konqueror I can see my file into DESKTOP name
" ZoneMinder-1.22.3.tar.gz"
Is it correct ?
And now what shall i do ?
How to install for upgrading ?
I have been reading LINUX for beginner, i red many lessons, but i could find how to do that.
Thank you for your help.
Best regards
pierrot
Is is correct ?
That's what i did.
Is it correct ?
Best regards
pierrot
no you need the rpm above ifthe link is down ross will be about soon enough if not im sure i can host it somewhere
James Wilson
if you want to upgrade a live cd install the best way is by rpm
If the link is down to ross's rpms (he is the guy that builds them) then its best you wait for ross, he is here most days
James Wilson
OK here is a new link
http://sentrix.homeip.net/rpms/
Always use the latest zm rpm you find for your distro version.
I think I have my firewall configured correctly so let me know if you are able to get the rpms you need. If so I will update the link in the wiki.
Hello Ross, thank you for your answer.
But i still do not understand.
Please can you read attentively my first message, and tell me if what i have done is RIGHT or NOT !
I don't understand why you drive me to the link you gave me.
"Release 1.22.3 23rd November 2006" is not an upgrade for the complete version from you " ZoneMinder LiveCD v1.22.2 DOWNLOAD ALT1 TORRENT " that i have downloaded and install, and which work correctly on my PC " ?
To answer to YOUR question, YES i was able to get RPM from URL you gave me ?
Thank you and best regards.
Pierrot
Pierrot
Here is the howto for the mandriva package manager. It describes howto update packages in Mandrake/Mandriva.
Sorry I haven't used the distro in a while and haven't kept current on their new package manager but this should get you going.
http://www.mandrakehelp.com/RPM-HOWTO.html
The way to upgrade your installation is to download the latest zm rpm from http://sentrix.homeip.net/rpms/mdk_2006/"Release 1.22.3 23rd November 2006" is not an upgrade for the complete version from you " ZoneMinder LiveCD v1.22.2 DOWNLOAD ALT1 TORRENT " that i have downloaded and install, and which work correctly on my PC " ?
Then in a konsole window enter the command "sudo rpm -Uvh zm-1.22.3-5.1.20060mdk.i686.rpm"
Then enter the command "sudo service zm restart" and you will be all up to date
Hi Ross
I have downloaded from http://sentrix.homeip.net/rpms/mdk_2006/
OK, my file is into" desktop" path is : /home/guest/desktop
When i open Konsole i have
[guest ~$]
i type "sudo rpm -Uvh zm-1.22.3-5.1.20060mdk.i686.rpm"
answer is : error open ZM......... no such file or directory.
I understand i am not at the right directory. So i go to
[/home/guest]# in red color.
same result = error open........
i go to root = same, etc.. etc..
Where shall i go ?
Thank for your help-
Pierrot
[guest ~$]
Where shall i go ?
Pierrot
you need to navigate to where the rpm is saved. Before you do the rpm -Uvh
do
dir
and check the rpm is listed. Id expect you to have to chnage to your Desktop directory and note when changing directory in linux its case sesitive
do
dir
James Wilson
Hello James
Sorry, but did you read what i wrote ?
You ask me to do exactly what i did ...
i told my file is into :/home/guest/desktop
i can assure it is there, because i have seen it with Konqueror.
[guest ~]$
if i type : dir
i got : Video Desktop Music rpm Pictures bin tmp and others
Those file are exactly the one i have seen with Konqueror.
if i type :
[guest ~]$ cd tmp
i got
[guest tmp]$
if i type :
[guest tmp]$ cd
i got
[guest ~]$ cd bin
i got
[guest bin]$
if i type:
[guest bin]$ cd
i got
[guest ~]$
if i type :
[guest ~]$ cd desktop
i got
bash: cd: desktop: No such file or directory
so i am able to change to some directory, but not to Desktop.
And that is the place where is my RPM .
I must do errors, but i don't see which one.
Best regards
Pierrot
[guest ~]$
if i type : dir
if i type :
[guest ~]$ cd tmp
i got
[guest tmp]$
if i type :
[guest tmp]$ cd
i got
[guest ~]$ cd bin
i got
[guest bin]$
if i type:
[guest bin]$ cd
i got
[guest ~]$
if i type :
i got
Best regards
Pierrot
With linux "desktop" is not he same as "Desktop".if i type :
i got
This is different than windows. All filenames, paths, passwords, and almost anthing else you may think of are case sensitive. If you see uppercase in the "ls" or "dir" output then you must use that.
If you like you can do it this way:
"sudo rpm -Uvh Desktop/zm-1.22.3-5.1.20060mdk.i686.rpm"
