hi,
I discovered ZM a few weeks ago and it's working really well on my ubuntu 7.04.
So I want to use it in my company, but I'm not sure they allow me to use a Linux distribution. Do you know if it is possible to install it on windows ? I saw that ZM4MS is under windows, but if I understood, it doesn't replace a ZM server.
Thank you for your help
installation of ZM on Windows
No you will need a linux box for zm. ZM4ms is purly a front end and you still need a zm box for it to talk to
James Wilson
it may be possible but it would take a lot of work. I for one wouldnt even attempt it, you could try virtualising on windows, not the greatest platform but may get you round it. IP cams only though im guessing
James Wilson
I uses v4linux, and you would have to port that first. Perhaps your company would be more accepting to Linux if you got a distribution with support... For example, http://www.ubuntu.com/support/paid for Ubuntu.
