I'm running Fedora Core 1, I installed zm with the following with:
./configure --with-mysql=/usr --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-ffmpeg=/usr/include/ffmpeg --with-webuser=apache --with-webgroup=apache
No errrors during the install, creating and starting the database. However, there are no files in /var/www/html/zm/ !?? I am missing something totally obvious? I'm assuming that if everything is properly installed, i would start with http://<IP>/zm/ , right ?
thx for any input,
zardo
I must be an idiot
Re: I must be an idiot
Hi zardo,
Forgive me for asking, but since your post doesn't say so:
Did you run 'make' and as root 'make install' in the zm build directory?
Also I use http://localhost/zm/
Ross
Ross
Hi Ross,
You confirmed that i am an idiot. I had not run "make install" - BTW, the README has only "make", so for the other newbies out there, you need to run "make install" after running "make".
zardo
zardo
If you're new to installing from source, and you have ZoneMinder working, give yourself a pat on the back.
It may not be rocket science, but its not point and click either.
Ross
Ross
