4 channel bttv card shows channel 1 on all channels
graemian
Post by graemian »
Hi all,
I have a 4 channel bttv card (card=116). All channels show the picture from channel 1. It seems I can't address channels 2,3 and 4, I can only see channel 1.
This isn't a ZoneMinder problem. Xawtv has the same problem. However, about a year ago, I had this card working perfectly in ZM, I just can't remember what I did.
Can anyone point me in the right direction?
Thanks,
Graeme
Lee Sharp
Post by Lee Sharp »
I would bet you had to modprobe it somewhere.
graemian
Post by graemian »
I don't understand - please can you explain what you mean
cordel
Post by cordel »
Try card=77 should work if this is the cad I think it is. A better discription would be more helpful.
