Alright,
every thing is in, together, and I have spent fifty hours this last week getting all the base stuff setup. So the OS's are installed and the server(s) are running and I'll be getting them configured over the next few weeks. I ran out of cash so I didn't get everything I had hoped for. I sacificed 2GB of Ram, got almost the cheapest Opteron F socket proc and didn't populate the other socket, and sacraficed the 3ware raid card and the cheaper rocket raid that I was looking at ( That's okay I'll wait for the 3ware card I think
. But thats okay as these can be added over time (besides it would be killer to get a couple quad cores when they come out
But that would just be playing now wouldn't it
). But, over all is seems to be performing better than I had anticipated and worst case I'll have to pick up another pair of ecc reg ram.
BTW, The Istar case is really nice, but with the Istar Hot-Swappable SATA HDD Enclosure, it overlaps the main board on the left side and is sitting right on top of the SATA cables, so much so that I don't like it, I would suggest going with the 3ware cages instead as they used the waste space on the side of the enclosure to place the fans instead of mounting them on the back and extending the overall length.
The urls are still the same and the packages are still in the same place but some were lost in the drive corruption but I moved what was left to the new system. I'm going to attempt to recover the drive from the build machine that blew up last year and get the rest of the packages and rebuild the repo.
If anyone would like to give me ssh access to their system (Has to be CTU core Distro) would be great and I could just pull the packages out of the cache and would be helpfull, time saving, and get me going forward a bit faster rather than working on data recovery
Also on the todo list is I'm going to setup a Trac site. Every one will be able to use this to report bugs in the RPM's and of course get support for the rpm packages. This may expand to supporting other packages as well if the need arrises and I might add apt or other update support as well if the demand is there. This would give other packagers access to use Trac as well to support their efforts.
I'll keep every one posted on
this thread.
