Minor issue with 1.22.3
domf
Post by domf »
I'm seeing a minor issue when running 1.22.3 on Ubuntu 7.04.
I have a number of monitosr setup running at 4CIF (704x576) with some at higher resolutions. The issue occurs in that several browser windows are created that do not have scroolbars so it is not possible to see all the contents on the screen.
One examples is:
If I have 3 monitors enables and click on "Montage" then half of the bottom monitor is cut off and no scroll bars exist on the window.
I do not believe this is a browser related issue as i see the same effect both locally using Firefox and remotely using IE.
I should point out that this is not a big deal for me but I consider zoneminder to be a very useful and quality piece of software so assume you'd rather I report issues as I find them so that they can get fixed in due course.
If there is any further information that I can supply to help then please feel free to ask!
Dom
