I've one super pc dedicated to zoneminder
ATHLON 64 X2 3800
1GB RAM
VIDEO CARD 4 CHANNEL WITH 3 CAMERAS
LINUX GENTOO
IF I CONNECT TO THIS SERVER WITH ANOTHER PC THE
CYCLING/MONTAGGIO FUNCTION WORK WELL
IF I START MOZILLA ON THE SERVER, THE CYCLING/MONTAGGIO FUNCTION SOMETIMES DO NOT SHOW ANYTHING... I'VE TO RELOAD THE PAGE MANY TIMES BEFORE TO HAVE THE 3 IMAGES....
WHY THIS ???
I USE SWF FOR FILMS....
________
Mercedes-benz m950f specifications
ZONEMINDER CLIENT/SERVER ON THE SAME MACHINE....
Mozilla is a pig. It will bump resources significantly. The is the xlib_shm 3rd party app that can help. http://www.zoneminder.com/wiki/index.php/Xlib_shm
you need to change some settings in firefox for it to work as expected but its not best to use ff on the host
James Wilson
Montage view / Firefox / Mozilla
Try the following:
enter about:config in the browser's address line, then find the respective parameters and change them as below. Afterwards, you should not have any trouble anymore.
browser.cache.check_doc_frequency: set to 1
browser.cache.disk.enable: set to false
browser.cache.memory.enable: set to false
network.http.use-cache: set to false
network.http.max-connections: set to 100
network.http.max-connections-per-server: set to 100
network.http.max-persistent-connections-per-proxy: set to 100
network.http.max-persistent-connections-per-server: set to 100
Cheers!
Cheers!
