this is a debian install 1.22.3 i think the below error is the main
problem
the zoneminder web page appears ok
dmseg looks good for the hardware
all the zm logs look good
xautv comes right up
the only log error is in apache
below-- one thing funny is no access log for apache which i think that is related to the error below
i had to put a link in to get zm up in /etc/apache2/conf.d to /etc/zm/apache.conf
i suspect there is something that needs to be set in an apache config file
properties from video window
location http://localhost/cgi-bin/zms?mode=jpeg& ... 1186459727
width 320px
height 240px
file size unknown
thank you
rob
apache errors no video
This sounds like a very similar issue that I encountered. After a little bit of troubleshooting it turned out to be something very simple, my apache configuration was incorrect and it was not mapping the /cgi-bin directory for web access. Not sure if that is your problem or not but the behavior sounds very similar. Good luck.
