I am having an problem setting up Modect:-
I have three zones setup on one monitor all zones are set to the Best - Highest, I get a Alarm Status but the status does not seem to be cancelled and the event shows up without a ID number and No secs and No Frames reg. If I click on the 'event' there is no stream 'blank image' but if I click on stills if shows the stills up OK.
Buffer settings
Image Buffer 40
warmup 15
Pre event 10
Post Event 10
Alarm Frame 1
It seems as if the alarm is not closing the event, I have the score setting @ 50.
I have had this working but for the life of me I cannot work it out what I have changed to cause this?
Also can anyone explain the figure settings on the min/max zone area sensitivity.
Is this figure out of the total zone area? so if zone area is 100
Min 16 (16/100)
modect -Alarm Status But No secs - No Frames ?[Resolved]
Does it monitor correctly? Can you record an event with the record setting? (10 minutes is default) How about mocord?
As to the min/max... The min setting is how many pixels (or more) have to change to trigger an event. The max setting is the upper threshold. That is so that if a light comes on, changing all pixels, you don't trigger an event. Also usefull for video "jumps" from poor signal.
Resolved
Many thanks Lee for your reply, thanks for explaining the 'min/max' I am slowly getting to grips with this great software.
I have resolved the issue with No Secs/No Frames/No Score - it was a db error, after running the db repair utils it works great ( There seems to have been a error in the stats database fields)
Edit 22:32 08/08/07
How do I repair the MySQL Database?
* mysqlcheck --all-databases --auto-repair -pyour_database_password -u your_databse_user
Edit 22:32 08/08/07
>sudo mysqlcheck --all-databases --auto-repair
