Hello
I have a compaq deskpro en P111 866mhz. with Xununtu and ZM installed. So far I`am loving it. I have two pelco cameras hooked up. Loads get to 2 or 3. Cameras are set to max 8fps and alarm max 10fps. I want more power. So
I have a old Soyo K7v Dragon Plus motherbord that I want to use for a 4-8 cctv setup. The max cpu I ca use is a 2100+ (1.73.ghz) and I`am going to max the ram with 3 gigs.
Will this be enough hoursepower?
Thanks for your help. This is the first time using this software.
cordel wrote:Unless you put together a 64 bit machine, I would not bother with more than 2 GB of ram since this is the limitation of the 32 bit architecture.
Don't you mean 4 gig? Well 3 gig after the graphics card and other devices are mapped? So he is actually right in the sweet spot.
I think that hardware will work fin You are a little tight on CPU, but acceptable. Memory is very good.
