/dev/video0 device permission problem
rrk
Post by rrk »
zm does not have permission to use /dev/video0
from the system log
zmdc log shows video0 crashing on a regular basis
current ownership of /dev/video0 is root and video
i have added www-data to the video group zmuser is not a system user should it be?
zm 1.23 from debian pkg
rob
rrk
Post by rrk »
which user from with in zmc is accessing /dev/video0
making zmuser a system user does not fix the problem
rob
PeterHoward
Post by PeterHoward »
The permissions aren't as obvious as you'd think . . there's a program /usr/bin/zmfix which should get the perms right (when run as root). Alternately the brute-force "sudo chmod 777 /dev/video0" will get things working :-)
rrk
Post by rrk »
thanks that worked I was trying to avoid the 777 club/stick
Lee Sharp
Post by Lee Sharp »
Then suid the zm-fix xcript.
jorloujr
Post by jorloujr »
Me too am facing the same problem, brute force chmod 666/dev/video0 does works, but zmfix do not ...
Any hints ?
I,m on Ubuntu 8.04, ZM installed from Synaptic.
PeterHoward
jorloujr wrote:Me too am facing the same problem, brute force chmod 666/dev/video0 does works, but zmfix do not ...
Any hints ?
zmfix needs to be run with root permissions to change things. So you either do Lee's trick of suid-ing the script, or you run "sudo zmfix".
PJH
jorloujr
Post by jorloujr »
PeterHoward wrote:zmfix needs to be run with root permissions ...
Thanks Peter !
I found
http://www.zoneminder.com/wiki/index.php/Ubuntu_7.04
and
worked fine. Silly me ...
