Yeah, sorry, my card is a no name with a Conexant Fusion 878A. This is a link to the card I'm using...
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... otohosting
Tryed entering the 2 options on separate lines into the /etc/modprobe.conf like this...
options bttv card=77
options bttv tuner=4
Didn't notice any difference. except the entire start up process seemed slower, over 5 minutes to boot.
During the boot sequence, takes a minute and a half to try load hardware drivers "Loading hardware drivers... [fail]"
Tryed entering the 2 options on separate lines into the /etc/modprobe.d/options file like I did in /etc/modprobe.conf after I deleted the /etc/modprobe.conf.
No noticeable difference. Other than xawtv keeps flashing between the 2 cameras I have running and xawtv prints...
"config: invalid value for input: Television valid choices for "input": "Composite0", "Composite1", "Composite2", "Composite3""
I notice when I reboot server, on the shutdown a message is displayed something along the lines of
"stopping ZoneMinder"
"Can't stop ZoneMinder, ZoneMinder is already stopped"
It was running when the server was running. Not sure if this is important.
I've spent somewhere in the vicinity of 100 hours on this install. Maybe I've screwed something else up?
The problem I have is that there is no clear cut install doc. That just works.
At lease I couldn't find one. Is there one besides the ones I've already mentioned?
I really don't want to go down the windows path, especially for a server and ZM looks like it would be a great package if I could get it configured.
This is the new dmesg...
[42949384.070000] Linux video capture interface: v1.00
[42949384.150000] bttv: driver version 0.9.16 loaded
[42949384.150000] bttv: using 8 buffers with 2080k (520 pages) each for capture
[42949384.150000] bttv: Bt8xx card found (0).
[42949384.150000] **** SET: Misaligned resource pointer: dfbcde02 Type 07 Len 0
[42949384.150000] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 12
[42949384.150000] PCI: setting IRQ 12 as level-triggered
[42949384.150000] ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [LNKC] -> GSI 12 (level, low) -> IRQ 12
[42949384.150000] bttv0: Bt878 (rev 17) at 0000:00:0a.0, irq: 12, latency: 32, mmio: 0xd5801000
[42949384.150000] bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[42949384.150000] bttv0: gpio: en=00000000, out=00000000 in=00f36fff [init]
[42949386.460000] Linux agpgart interface v0.101 (c) Dave Jones
[42949386.910000] input: PC Speaker as /class/input/input1
[42949386.940000] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[42949387.050000] agpgart: Detected VIA Apollo Pro 133 chipset
[42949387.050000] agpgart: AGP aperture is 8M @ 0xd5000000
[42949400.150000] bttv0: using tuner=4
[42949400.150000] bttv0: i2c: checking for TDA9875 @ 0xb0... **** SET: Misaligned resource pointer: dfbcd102 Type 07 Len 0
[42949400.150000] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
[42949400.150000] PCI: setting IRQ 11 as level-triggered
[42949400.150000] ACPI: PCI Interrupt 0000:00:09.0[A] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
[42949400.150000] 3c59x: Donald Becker and others.
www.scyld.com/network/vortex.html
[42949400.150000] 0000:00:09.0: 3Com PCI 3c905C Tornado at e0976000. Vers LK1.1.19
[42949416.150000] not found
[42949416.150000] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[42949432.150000] bttv0: i2c: checking for TDA9887 @ 0x86... not found
[42949565.330000] ACPI: PCI Interrupt 0000:00:09.0[A] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
[42949570.450000] lp: driver loaded but no devices found
[42949572.060000] Adding 1044216k swap on /dev/hda3. Priority:-1 extents:1 across:1044216k
[42949573.500000] NET: Registered protocol family 10
[42949573.500000] lo: Disabled Privacy Extensions
[42949573.500000] IPv6 over IPv4 tunneling driver
[42949575.290000] EXT3 FS on hda1, internal journal
[42949577.490000] md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
[42949577.490000] md: bitmap version 4.39
[42949583.700000] eth0: no IPv6 routers present
[42949595.250000] device-mapper: 4.4.0-ioctl (2005-01-12) initialised:
dm-devel@redhat.com
[42949661.440000] cdrom: open failed.
[42949677.490000] kjournald starting. Commit interval 5 seconds
[42949677.990000] EXT3 FS on hda2, internal journal
[42949677.990000] EXT3-fs: mounted filesystem with ordered data mode.
[42949768.170000] bttv0: registered device video0
[42949768.170000] bttv0: registered device vbi0
[42949768.170000] bttv0: PLL: 28636363 => 35468950 .. ok
[42949768.220000] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[42949768.320000] bt878: AUDIO driver version 0.0.0 loaded
[42949768.320000] bt878: Bt878 AUDIO function found (0).
[42949768.320000] ACPI: PCI Interrupt 0000:00:0a.1[A] -> Link [LNKC] -> GSI 12 (level, low) -> IRQ 12
[42949768.320000] bt878(0): Bt878 (rev 17) at 00:0a.1, irq: 12, latency: 32, memory: 0xd5802000
[42950347.030000] bttv0: PLL can sleep, using XTAL (28636363).
[42950347.140000] bttv0: PLL: 28636363 => 35468950 .. ok
