No images displayed in montage.
nkw
Post by nkw »
After installing ZM (Opensuse-10.2). I have no images in the montage.
The windows appear.
In the top left, a favicon with "new" listed next to it. Below, "Status: Idle - 0.00 fps". It actively seeks information, however, in properties it list a file size of zero.
Any suggestions...
jameswilson
Post by jameswilson »
DO you have images in the normal monitor view, are you capturing images etc
Sounds like you have a cam config error to me
James Wilson
nkw
Post by nkw »
I just returned from holiday, sorry for not responding.
I have no images anywhere. I am using a DVR card and all drivers are showing installed correctly. The drivers listed are the same as the drivers I am using in Window’s XP pro which work fine (dual boot).
Lee Sharp
Post by Lee Sharp »
What card?
Have you tried xawtv?
What modprobe options are you using?
Post your lspci and dmesg here as well.
nkw
Post by nkw »
The card is non branded 16 channel, using Philips SAA7130 chip.
I am new to linux, so I do not know what xawtv, modprobe, lspci and, dmesg does.
what do I do?
cordel
Post by cordel »
nkw wrote:I am new to linux, so I do not know what xawtv, modprobe, lspci and, dmesg does.
what do I do?
You will need to learn linux :wink:
I put a few links at the bottom of this link that have tutorials and such that help new linux users.
Lee Sharp
Post by Lee Sharp »
nkw wrote:Hi,
what do I do?
Additionally, I recommend http://catb.org/~esr/faqs/smart-questions.html
Always give as much information as you can. Some short explanation as to why.
We need to know what card. Post a link to a picture. That is because some cards are autodetected, but most are not. We know a lot of them...
lspci is a command to show what is on your PCI bus. dmesg is a list of what Linux thinks is on your pci bus. modprobe is a way to tell Linux what is really on your pci bus. xawtv is a way to test video capture.
neilk
Post by neilk »
