Strange image properties 127.0.0.1192.168.0.162
wat
Post by wat »
Intellinet camera on address 192.168.0.162.
shops up in browser under http://192.168.0.162/monitoring.cgi, but
in Zoneminder the image is blank with the location http://127.0.0.1192.168.0.162/jpg/image.jpg..... the two ips written
as such. The remote ip address in source is correct.
Should I do a new install of Zoneminder or could anyone suggest a simplier
solution ?
Ubuntu 7.04.
My thanks in advance
Antimon
Post by Antimon »
Are you sure those two ips have to be written in this way? This target doesn't exist - 127.0.0.1 would be localhost, 192.168.0.162 the camera.
Which values did you insert into zm's config?
The hostname should be "192.168.0.162" and the path "/jpg/image.jpg"
Do you use these values?
wat
Post by wat »
yes, the
remote host name = 192.168.0.162
remote host path /jpg/image.jpg
form where ZM adds the localhost in front of this ??
thanks for yr help
wat
Post by wat »
what should the path be (in options) in case of a remote camera ?
from the path is created the image properties
jameswilson
Post by jameswilson »
what do you have in your paths of the main config (not the monitor)
James Wilson
