need help with fedora install
zoneminder is already In Fedora 7
All this mess for nothing?
Application Menu
Get software
Search and install zoneminder 1.22.3-7.fc7.i386
Application Menu
Get software
This problem is also in evidence on Slackware 12.0 Adding the 3 lines above fixed the problem without difficulty though. (The only difficulty was the stress I put myself under between the time the compile failed and I came here to check for a solution.
This message is made up of not less than 90% recycled electrons.
