set record diagnostic images separately for each monitor
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
hrabe
Post by hrabe »
I thing, that may be very useful set option record diagnostic images separately for each monitor. When I have about 10 monitors and I would "debug" new one, I have function-less diag images from old 10 monitors...
Thanks,
M.
jameswilson
Post by jameswilson »
As diag is normally used temp i think its better to waste them and have a global option. You dont leave it enabled do you? Apart from the increased load whats the problem having diag on all monitors?
James Wilson
hrabe
Post by hrabe »
Yes, problem is the load and bandwith for bus and disk. This is the similar reason as http://www.zoneminder.com/forums/viewtopic.php?t=9096.
