Progress bar does not work, DVR interface too
Event view progress bar does not work, DVR interface does not work too. Distro Slackware 11.0.0, all browsers.
hi,
to get the DVR interface working you have to install mootools. I dont't know which components are needed so select all and move the downloaded file to your zm web directory and rename it to "mootools.v1.11.js". after this the DVR interface should work
hope this helps
hope this helps
- zoneminder
- Site Admin
- Contact:
Where is the WEB directory?monex wrote:hi,
hope this helps
