Progress bar does not work, DVR interface too
hrabe
Post by hrabe »
Event view progress bar does not work, DVR interface does not work too. Distro Slackware 11.0.0, all browsers.
monex
Post by monex »
hi,
to get the DVR interface working you have to install mootools. I dont't know which components are needed so select all and move the downloaded file to your zm web directory and rename it to "mootools.v1.11.js". after this the DVR interface should work :)
hope this helps
hrabe
Post by hrabe »
monex: thank you very much for your great response, now DVR interface is more better, but with some problems.
zoneminder
Site Admin
Post by zoneminder »
Yes, installing mootools is extremely important and I totally forgot to mention it!
Phil
gola10
Post by gola10 »
monex wrote:hi,
hope this helps
Where is the WEB directory?
cordel
Post by cordel »
He means your web root directory.
