Xawtv not saving settings
BadFish
Post by BadFish »
I have installed ZM 1.22.3 on Fedora 6 and everything seems to work. when I use xawtv I change the settings from Pal to NTSC and Television to Comp 1. However if I restart zm I get a black screen and I then have to go back to the box and open xawtv and reset the settings again. My issues is how do I save the settings so that I can restart ZM or the machine and not have to redo the settings ever time.
BadFish
Post by BadFish »
Here is the Modprobe.conf
[root@localhost etc]# cat modprobe.conf
alias eth0 e100
alias snd-card-0 snd-cmipci
options snd-card-0 index=0
options snd-cmipci index=0
remove snd-cmipci { /usr/sbin/alsactl store 0 >/dev/null 2>&1 || : ; }; /sbin/modprobe -r --ignore-remove snd-cmipci
Dmesg
SELinux: Starting in permissive mode
selinux_register_security: Registering secondary module capability
Capability LSM initialized as secondary
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 256K
CPU: After all inits, caps: 0383f1ff 00000000 00000000 00000040 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 12k freed
ACPI: Core revision 20060707
ACPI: setting ELCR to 0200 (from 0c20)
CPU0: Intel Pentium III (Coppermine) stepping 06
SMP motherboard not detected.
Local APIC not detected. Using dummy APIC emulation.
Brought up 1 CPUs
sizeof(vma)=84 bytes
sizeof(page)=32 bytes
sizeof(inode)=424 bytes
sizeof(dentry)=148 bytes
sizeof(ext3inode)=600 bytes
sizeof(buffer_head)=52 bytes
sizeof(skbuff)=172 bytes
sizeof(task_struct)=1392 bytes
checking if image is initramfs... it is
Freeing initrd memory: 2118k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xf0d00, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
PCI quirk: region e800-e80f claimed by vt82c686 SMB
PCI: Firmware left 0000:00:08.0 e100 interrupts enabled, disabling
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 14 devices
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
NetLabel: Initializing
NetLabel: domain hash size = 128
NetLabel: protocols = UNLABELED CIPSOv4
NetLabel: unlabeled traffic allowed by default
pnp: 00:03: ioport range 0xe400-0xe47f could not be reserved
pnp: 00:03: ioport range 0xe800-0xe80f has been reserved
PCI: Bridge: 0000:00:01.0
IO window: d000-dfff
MEM window: bd000000-bdffffff
PREFETCH window: c0000000-fbffffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 6, 327680 bytes)
TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
Simple Boot Flag at 0x3a set to 0x1
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
apm: overridden by ACPI.
audit: initializing netlink socket (disabled)
audit(1190922011.432:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SELinux: Registering netfilter hooks
Initializing Cryptographic API
ksign: Installing public key data
Loading keyring
- Added public key EAA0802BFF323905
- User ID: Red Hat, Inc. (Kernel Module GPG key)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
PCI: Disabling Via external APIC routing
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Processor [CPU0] (supports 16 throttling states)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12ac
Non-volatile memory driver v1.2
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected VIA Apollo Pro 133 chipset
agpgart: AGP aperture is 32M @ 0xfc000000
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0b: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 16384K size 4096 blocksize
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:04.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt82c686b (rev 40) IDE UDMA100 controller on pci0000:00:04.1
ide0: BM-DMA at 0xb800-0xb807, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xb808-0xb80f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
hda: WDC WD400BB-00AUA1, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: PLEXTOR CD-R PX-W1210A, ATAPI CD/DVD-ROM drive
hdd: YAMAHA CRW2100E, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(33)
hda: cache flushes not supported
hda: hda1 hda2
ide-floppy driver 0.99.newide
usbcore: registered new driver libusual
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: bitmap version 4.39
TCP bic registered
Initializing IPsec netlink socket
NET: Registered protocol family 17
Using IPI No-Shortcut mode
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 240k freed
Time: tsc clocksource has been installed.
Write protecting the kernel read-only data: 370k
Time: acpi_pm clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
PCI: setting IRQ 10 as level-triggered
ACPI: PCI Interrupt 0000:00:04.2[D] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ 10
uhci_hcd 0000:00:04.2: UHCI Host Controller
uhci_hcd 0000:00:04.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:04.2: irq 10, io base 0x0000b400
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:04.3[D] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ 10
uhci_hcd 0000:00:04.3: UHCI Host Controller
uhci_hcd 0000:00:04.3: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:04.3: irq 10, io base 0x0000b000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
input: PS/2 Generic Mouse as /class/input/input1
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
SELinux: Disabled at runtime.
SELinux: Unregistering netfilter hooks
audit(1190922021.044:2): selinux=0 auid=4294967295
hdc: ATAPI 32X CD-ROM CD-R/RW drive, 2048kB Cache, DMA
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 40X CD-ROM CD-R/RW drive, 8192kB Cache, UDMA(25)
input: PC Speaker as /class/input/input2
parport_pc: VIA 686A/8231 detected
parport_pc: probing current configuration
parport_pc: Current parallel port base: 0x378
parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
Linux video capture interface: v2.00
via686a 0000:00:04.4: base address not set - upgrade BIOS or use force_addr=0xaddr
parport_pc: VIA parallel port: io=0x378, irq=7
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
PCI: setting IRQ 5 as level-triggered
ACPI: PCI Interrupt 0000:00:09.0[A] -> Link [LNKD] -> GSI 5 (level, low) -> IRQ 5
bttv0: Bt878 (rev 17) at 0000:00:09.0, irq: 5, latency: 32, mmio: 0xbe800000
bttv0: detected: Hauppauge WinTV [card=10], PCI subsystem ID is 0070:13eb
bttv0: using: Hauppauge (bt878) [card=10,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffdb [init]
bttv0: Hauppauge/Voodoo msp34xx: reset line init [5]
tveeprom 1-0050: Hauppauge model 44801, rev D182, serial# 7229621
tveeprom 1-0050: tuner model is LG TAPC H791F (idx 82, type 39)
tveeprom 1-0050: TV standards NTSC(M) (eeprom 0x08)
tveeprom 1-0050: audio processor is None (idx 0)
tveeprom 1-0050: has no radio
bttv0: Hauppauge eeprom indicates model#44801
bttv0: using tuner=39
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
tuner 1-0061: chip found @ 0xc2 (bt878 #0 [sw])
tuner 1-0061: type set to 39 (LG NTSC (newer TAPC series))
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
e100: Intel(R) PRO/100 Network Driver, 3.5.10-k2-NAPI
e100: Copyright(c) 1999-2005 Intel Corporation
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:00:08.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
e100: eth0: e100_probe: addr 0xbf800000, irq 11, MAC addr 00:90:27:3A:23:F7
ACPI: PCI Interrupt 0000:00:05.0[A] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ 10
ACPI: PCI Interrupt 0000:00:09.1[A] -> Link [LNKD] -> GSI 5 (level, low) -> IRQ 5
bt878: AUDIO driver version 0.0.0 loaded
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
lp0: using parport0 (interrupt-driven).
lp0: console ready
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
[drm] Initialized drm 1.0.1 20051102
ACPI: PCI Interrupt 0000:01:00.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
[drm] Initialized radeon 1.25.0 20060524 on minor 0
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
device-mapper: multipath: version 1.0.4 loaded
EXT3 FS on dm-0, internal journal
EXT3 FS on hda1, internal journal
Adding 851960k swap on /dev/VolGroup00/LogVol01. Priority:-1 extents:1 across:851960k
