Help! My Debian Unstable and Axis 206 dont seem to work.
jameswilson
Post by jameswilson »
you grabing via jpeg or mjpeg, ie whats the path your using~?
James Wilson
trevorj
Post by trevorj »
/axis-cgi/mjpg/video.cgi?resolution=320x240
The resolution settings are correct, and that is the path I'm using.
jameswilson
strange i had issues with jpeg grab on a 206m.
I use 206's on many sites with great success. Try using jpeg grabs and see if that helps
James Wilson
trevorj
Post by trevorj »
I will as soon as the camera itself is operational again. I tried to flash the firmware and it sort of died midway through, so now I have to wait for Axis tech support to tell me how to flash the memory.
jameswilson
ah
good luck lol
James Wilson
jameswilson
just had a thought you arnt trying to throttle the fps in zm on a mjpeg feed are you, ie your throttling the cam?
James Wilson
trevorj
Post by trevorj »
I have the Max FPS set to 12 via ZM, yes.
jameswilson
thats your problem then
set it to 12 on the cam, or use jpg stream
James Wilson
trevorj
Post by trevorj »
Ah! I will test this when my camera works again and get back to you about the results.
jameswilson
ok matey
James Wilson
trevorj
Post by trevorj »
Okay. It seems to be working without the frame constraint.
If I want to force users to log in to view the camera image, how do I go about passing a username/password along to Zoneminder, so it can log in?
jameswilson
you mean on the cam?
if so add
user:pass@123.123.123.123
to the host once you have set a pass etc on the cam
James Wilson
trevorj
Post by trevorj »
Thanks! I figured it out by myself just as you posted it.
I think it's actually working now.
