gadspot gs1200
denis
gadspot gs1200
Post by denis »
i've read that this camera is working with zm, so i've bought it!
but in the log sometimes it send bogus jpeg,
and after some minutes it's compeltely freeze!
it doesn't cost too much, but the price is proportionally to the value of camera. i'm think that it's a very bad camera.
jameswilson
Post by jameswilson »
There seem to be lots of issues. As with everything stick to axis for reliability.
James Wilson
Flash_
Post by Flash_ »
It seems that the newer gadspots aren't as compatible as the older ones. Not sure of the details but you;re not the first. My 1200 works fine but it's looking like I'm one of the lucky ones. :(
denis
Post by denis »
Flash_ wrote:It seems that the newer gadspots aren't as compatible as the older ones. Not sure of the details but you;re not the first. My 1200 works fine but it's looking like I'm one of the lucky ones. :(
what's your firmware version?
