Hi.
Now i have finaly get all working and itś great.
But if i change so i have to login to the system then the webinterface stops working.
It only returns to the loginpage ..
The only thing todo is execute the perl zmconfig.pl again and change the parameter.
Anyone has a clue?
//Per
Loginpage..
- zoneminder
- Site Admin
- Contact:
Re: Loginpage..
Hi Per,
Do you get any error messages when your login fails?
Have you got cookies enabled?
Have you set up your users, or are you using the default admin user?
Regards,
Phil,
Regards,
Phil,
Re: Loginpage..
Caught me the first time.
The default login is
admin/admin
Goto options and then change the username/password
admin/admin
