Image Buffer Size (frames)
malvo
Post by malvo »
cause memory gotten expensive again, i want to tweak the memory usage as low as possible.
What size should the ring buffer ie the value "Image Buffer Size (frames)" have?
Should it be:
Image Buffer Size (frames) = Pre Event Image Buffer + 1
or will this cause problems?
does it somehow depend on fps-settings?
on the load of the machine?
do i get penalties by lowering the value?
