Hi -
I am having troubles getting an image to show up from my Axis 213 camera and was wondering if someone could help me with some settings.
Here is what i have:
Remote Host Name: ip address
Remote Host Port: 80
Remote Host Path: /axis-cgi/mjpg/video.cgi?resolution=4CIF
Capture Width (pixels): 640
Capture Height (pixels): 480
Orientation: Normal
I would like to disable anonymous access to the camera and supply a user and password but I enabled anonymous access for testing
For the Axis camera i have these default settings:
Aspect Ratio Correction: On
4CIF (640x480)
Compression: 30
Rotate Image: 180
Color Settings: Color
Brightness: 30
Video Format: Motion JPEG
any ideas? No image shows up when i click on the name of the camera
I have another local device that works great. I do not have another network camera to test with. Thanks ,
Axis 213 PTZ settings
Jedibyte
I am still experiencing the same issue. If i enter this path in a web browser the image comes up from the camera. it is not streaming it is just one still image. The browser seems to be delayed as if it is trying to refresh.
the path im using in a web browser is
http://<ip address>/axis-cgi/video.cgi?resolution=640x480
Thanks for your help,
Jedibyte
thanks
Thanks. I got it working by increasing my shared memory. Instructions found in the FAQ http://www.zoneminder.com/wiki/index.php/FAQ
Thanks again, Now to try PTZ control .
Jedibyte
