Anyone is having this issue. It happens only at shutdown of ZM
Shutting ZoneMinder: DBI connect('database=zm;host=localhost','zmuser',...) failed: Access denied for user 'zmuser'@'localhost' (using password: YES) at /usr/share/perl5/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/ZoneMinder/Config.pm line 91.
Starting looks fine. it is bothering me for the SQL DB health
install Details:
Mandriva 2008
mySQL 5.1
perl 5
How do i check if i am missing any perl modules (DBI is not installed properly i think )
DBI connect error during shut down only
Found the problem but need advice
I found why this error is happenning : mysqld is shutting down before zm in the rcX.d files.
I know how to change the K00 order to K10 or K20 ... on K00mysqld but does anyone know which services have to stay alive before i get to the shutdown instruction K10mysqld. Presently all of them have K00 (http, netconsole,...
- zoneminder
- Site Admin
- Contact:
