help Configure zm with AIC250W
hello, I am trying to configure zm with cameras wireless Airlink 101 , I have a router dlink DI-634M I have open the ports 9293 , but I am not sure if I am making the correct thing when I add the monitors
these they are the data:
Router D-link : IP - 197.0.0.4
General:
Source Type: REMOTE
Function: Monitor
Enabled: check
Reference Image Blend %ge: 7
SOURCE:
Remote Host Name: ricky:PASSWORD@197.0.0.4
Remote Host Port: 9293
Remote Host Path: camera1.jpg
Remote Image Colors: 24 BITS
Capture Width (pixels): 640
Capture Height (pixels): 480
with this configuration it doesn't show me anything, I see in the log these errors:
Jan 22 13:04:12 xserver zmc_m1[13124]: ERR [Can't connect to remote camera: Connection refused]
Jan 22 13:04:12 xserver zmc_m1[13124]: ERR [Unable to connect to camera]
Jan 22 13:04:12 xserver zmc_m1[13124]: ERR [Failed to pre-capture monitor 0]
Jan 22 13:04:12 xserver zmdc[13071]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jan 22 13:04:14 xserver zmdc[13071]: INF [Starting pending process, zmfilter.pl]
Jan 22 13:04:14 xserver zmdc[13126]: INF ['zmfilter.pl' started at 08/01/22 13:04:14]
Jan 22 13:04:14 xserver zmdc[13071]: INF ['zmfilter.pl' starting at 08/01/22 13:04:14, pid = 13126]
Jan 22 13:04:14 xserver zmdc[13071]: ERR ['zmfilter.pl ' exited abnormally, exit status 9]
I am using Centos 5
General:
Source Type: REMOTE
Function: Monitor
Enabled: check
SOURCE:
I am using Centos 5
Re: help Configure zm with AIC250W
This means That either your port is wrong for this cam or the path is wrong or both. It could also be your login info is not correct. The cam itself is denying you access.rickygm wrote: Jan 22 13:04:12 xserver zmc_m1[13124]: ERR [Can't connect to remote camera: Connection refused]
I would suggest trying without authentication on the cam first and get it working, then you can work at turning auth back on.
ok the connection problem with the camera, my firewall that blocked the port, already opened the port but it shows me other errors the zm, but they are no longer connection problems if not of zm
Jan 22 18:18:35 xserver zmc_m1[10975]: ERR [Unable to get response]
Jan 22 18:18:35 xserver zmc_m1[10975]: ERR [Failed to post-capture monitor 0]
Jan 22 18:18:35 xserver zmdc[10903]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jan 22 18:21:14 xserver zmdc[10903]: INF [Starting pending process, zmfilter.pl]
Jan 22 18:21:14 xserver zmdc[10903]: INF ['zmfilter.pl' starting at 08/01/22 18:21:14, pid = 10994]
Jan 22 18:21:14 xserver zmdc[10994]: INF ['zmfilter.pl' started at 08/01/22 18:21:14]
Jan 22 18:21:14 xserver zmdc[10903]: ERR ['zmfilter.pl ' exited abnormally, exit status 9]
Jan 22 18:21:15 xserver zmdc[10903]: INF [Starting pending process, zmc -m 1]
Jan 22 18:21:15 xserver zmdc[10996]: INF ['zmc -m 1' started at 08/01/22 18:21:15]
Jan 22 18:21:15 xserver zmdc[10903]: INF ['zmc -m 1' starting at 08/01/22 18:21:15, pid = 10996]
Jan 22 18:21:15 xserver zmc_m1[10996]: INF [Debug Level = 0, Debug Log = <none>]
Jan 22 18:21:15 xserver zmc_m1[10996]: INF [Starting Capture]
Jan 22 18:21:15 xserver zmc_m1[10996]: ERR [Invalid response status 404: File Not Found]
Jan 22 18:21:15 xserver zmc_m1[10996]: ERR [Unable to get response]
Jan 22 18:21:15 xserver zmc_m1[10996]: ERR [Failed to post-capture monitor 0]
Jan 22 18:21:15 xserver zmdc[10903]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jan 22 18:03:13 xserver zms[6558]: ERR [Backtrace: /var/www/cgi-bin/nph-zms [0x80675bb]]
Jan 22 18:03:13 xserver zms[6558]: ERR [Backtrace: /var/www/cgi-bin/nph-zms [0x804b1fc]]
Jan 22 17:59:47 xserver zmwatch[6179]: INF [Restarting capture daemon for cam1, shared memory not valid
I remove the user camera and alone he leaves the ip, but it doesn't show me anything
This is becuase your path for the cam is incorrect. So the cam is now letting you in but there is no script or image at the path given.rickygm wrote:Jan 22 18:21:15 xserver zmc_m1[10996]: ERR [Invalid response status 404: File Not Found]
A search of the forums turns up that you path should be: video.cgi
http://www.zoneminder.com/forums/viewto ... irlink+101
ok changes the data in the zoneminder , ok changes the data in the zoneminder, but I continue without being able to see anything in zoneminder
this option thinks that the problem can be
==>( xserver zma_m1[5059]: WAR [Waiting for capture daemon]<=====
Jan 22 22:30:52 xserver zmc_m1[5443]: ERR [Select timed out]
Jan 22 22:30:52 xserver zmc_m1[5443]: ERR [Unable to get response]
Jan 22 22:30:52 xserver zmc_m1[5443]: ERR [Failed to post-capture monitor 0]
Jan 22 22:30:52 xserver zmdc[5030]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jan 22 22:30:52 xserver zmdc[5030]: INF [Starting pending process, zmc -m 1]
Jan 22 22:30:52 xserver zmdc[5485]: INF ['zmc -m 1' started at 08/01/22 22:30:52]
Jan 22 22:30:52 xserver zmdc[5030]: INF ['zmc -m 1' starting at 08/01/22 22:30:52, pid = 5485]
Jan 22 22:30:52 xserver zmc_m1[5485]: INF [Debug Level = 0, Debug Log = <none>]
Jan 22 22:30:52 xserver zmc_m1[5485]: INF [Starting Capture]
[/b]
[/b]
zma has nothing to do if zmc for any reason can not capture an image.rickygm wrote:ok changes the data in the zoneminder , ok changes the data in the zoneminder, but I continue without being able to see anything in zoneminder
[/b]
zmc is the capture binary.
zma is the analysis binary that checks for changes in the pixils (motion) from a captured image.
So your problem is still the same, trying to get a image from the camera.
does it sometimes show me this error, and the path of the cgi this correct one to that that can be?
I don't understand that mean with that !!!
thank you for your appreciated help
rickygm
xserver zmc_m1[10437]: INF [Starting Capture]
Jan 23 09:47:01 xserver zms[10500]: INF [Debug Level = 0, Debug Log = <none>]
Jan 23 09:47:02 xserver zms[10500]: ERR [Got signal (Floating point exception), crashing]
Jan 23 09:47:02 xserver zms[10500]: ERR [Signal address is (nil), from 0x80675bb ]
Jan 23 09:47:02 xserver zms[10500]: ERR [Backtrace: /var/www/cgi-bin/nph-zms [0x80675bb]]
Jan 23 09:47:02 xserver zms[10500]: ERR [Backtrace: /var/www/cgi-bin/nph-zms [0x804b1fc]]
Jan 23 09:47:02 xserver zms[10500]: ERR [Backtrace: /lib/libc.so.6(__libc_start_main+0xdc) [0xb94dec]]
Jan 23 09:47:02 xserver zms[10500]: ERR [Backtrace: /var/www/cgi-bin/nph-zms(__gxx_personality_v0+0x225) [0x804a331]]
Jan 23 09:47:02 xserver zms[10500]: INF [Backtrace complete]
[/b]
rickygm
[/b]
It means that zmc is still not able to get an image from the cam.
If you put the following in a Firefox browser you should get a streaming image:
http://197.0.0.4/video.cgi
If you do get a image in Firefox, check the properties and make sure you have the same image dimintions set in ZM for that cam. Also try /video.cgi for the path.
already try to put the 197.0.0.4/video.cgi, and the connection fails, but if I put in firefox 197.0.0.4:9393, I can see from my pc the connected remote camera to the router wireless
Router >>> 197.0.0.4
camera >>> 192.168.2.158
pc client >>> 197.0.0.2
the video resolution has it in zm 320x240 and the camera 320 x 240
thank cordel
that but it can be happening?
thank cordel
Opps, I forgot that you were using a different port so does the following work and if so what are the properties of the image?
http://197.0.0.4:9393/video.cgi
jejej , if I am confused, because if I can see the image in firefox, that means that the redirect of ports and the camera this well, but the problem is that zm not this understanding the access to the camera, I have put in the Remote Host Path: /video.cgi
but it doesn't still work me, I have left loading the image and it doesn't show it to me
But answer this pls,
Can you see the image using the link I gave you in your browser?
If you see the image with the link I gave you in the browser, what are the images properties?
cordel wrote:http://197.0.0.4:9393/video.cgi
I can see the images that the camera takes, putting in firefox 197.0.0.4:9293/video.cgicordel wrote:But answer this pls,
the size of the image is 320 x 240
he sends you a mail to hotmail, with a zm image
