Hi, i don't know how can I install cambozola in my slackware 9.1.
I download cambozola 2.2 and put in /var/www/htdocs, but he still not work...java console in IE don't recognize him.I'm missing anything ?
cambozola on slackware 9.1
- zoneminder
- Site Admin
- Contact:
I have ZM_PATH_CAMBOZOLA t -> cambozola.jar
I have checked ZM_OPT_CAMBOZOLA
Is something else ?
How can I install cambozola, step by step ? I only put the file 'cambozola.jar' in the /var/www/htdocs.
Is something else ?
Is something else ?
Is something else ?
Hi, Fernando
My apache2 server on slackware 9.1 don´t have /var/www/html.I install livecd and everthing works fine...I just can´t put cambozola to work on slackware...any clues ?
your version number of cambozola is strange. you claim to be using 2.2, but i have downloaded version 0.34?
i have successfully compiled and run cambozola under slackware 9.1. the most important thing to understand is that if you built cambozola with the default java environment runnning on slackware, you will need the latest sun j2re for your browser. ie: the msjava in internet explorer won't work. there is a note about this on a the cambozola website.
i had issues until i downloaded the latest j2re from sun and then everything started working fine for me.
another option you can try for the video (if you are using Internet Explorer running under Windows) is the MPEG streaming. this works fairly well also, but it's not as fast to start up as cambozola.
from the ZM console, go options -> video and select "MPEG" as the video stream.
hope this helps!
cheers, wizdude
hope this helps!
cheers, wizdude
Wizdude,
I was trying to compile cambozola-0.34 on RH 9 +Jrelatest+ant-1.61 when i got build error concerning property.application file, tried the same on windoze+ant+jdk1.2.2 same error (although it build cambozola.jar +cambozola-server.jar, neither of which i trust since they are less then half the size of cambozola-0.22.jar available on the zonemindersite) when trying to build again on windoze there was no output in the dist folder at all, do you have a workaround for the property file issue (I mailed andy (charlie mouse) but no answer and (probably not related, his site out today aswell) build error replicated below.
root@hakzo cambozola-0.34]# ant
Buildfile: build.xml
[property] Unable to find resource application.properties
init:
BUILD FAILED
file:/root/cambozola-0.34/build.xml:29: Could not create task or type of type: propertyfile.
from the author: the lines should read:
< property file="application.properties"/>
and
<property file="build.number"/>
hope this helps
peter kh
init:
BUILD FAILED
and
hope this helps
peter kh
- zoneminder
- Site Admin
- Contact:
