1.23.1 rpm is available?
If it was me, I'd leave it alone until the next rpm is available in the repo.
If you understand how to create the build eviroment and confortable with and building the source you can remove the package and build from source. The database is upgradable so you don't have to drop it, but make a backup of your database and events just in case the removal of the package takes those away ( they should not as they are using one of my old spec files for the build, but I don't know what they might have changed). You also have to make sure you have all the dependancies for the development enviroment.
