Date & Time in logs?
hvisser
Post by hvisser »
What determines the way the date & time is displayed in the logs (/tmp/zmfilter.log, etc)?
Mandriva 2008.0 Free. Installed 1.23.0 from RPM, then upgraded to 1.23.1 by compiling from source.
Before upgrade date was displayed in the logs as dd/mm/yyyy (UK/GB format), now since upgrade it is displayed as mm/dd/yyyy (US format)
I checked options in ZM and ZM_LANG_DEFAULT is set to "en_gb"
zoneminder
Site Admin
Post by zoneminder »
That is very curious. It is the same on my box.
The date format is strftime %x which should adopt a format appropriate to the locale but even though my locale is en_GB is still does the US style.
Nothing has changed in the debug files for about two years so I confess I don't know what it is. I will have to investigate further.
Phil
