Reset events and frames ID number
gola10
Post by gola10 »
I have ZM 1.22.3 installed from ZM Mandriva 2007 livecd. This computer was attacked by a hacker so i better reinstall. But i want to keep y settings.
One way to go is to backup the database and restore it on the new installation. (at least that i what i plan. But would like to reset reset frame ID number and Events ID number. Frames number is already 8 digits and events 6 digits.
Is there a script to reset this databases and the autoincrement field?
Lee Sharp
Post by Lee Sharp »
Start here. http://www.zoneminder.com/forums/viewtopic.php?t=11005 However, changing things can add some different problems. Be careful.
zoneminder
Site Admin
Post by zoneminder »
Although you can reset the events and frame indexes etc this will only work if you do not have entries in the DB already. If you add even just one event with an id of 1000000 then the next one will be 10000001 regardless. If you have an empty DB you can reset the counts with
alter table Events auto_increment=1;
etc.
Phil
Alan87i
A bit more detail
Post by Alan87i »
Could someone please explain a little further where or what a fellow is to do with this code ( alter table Events auto_increment=1 ) to make use of it?
MikeH
Post by MikeH »
It's a SQL statement that could be run against the ZM database using phpMyAdmin or some similar tool.
